PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 [59] 60 61 62
  1. Vdc
  2. GT Motorsports: GTM Twin Turbo Systems for VQ DE, HR, and VHR Engines
  3. RPM Meter
  4. HR-TT Project Near Completion
  5. This ever happen to anyone else?
  6. G37 Twin Turbo kit
  7. 32 miles and service engine soon light
  8. Gasket
  9. Clutch/Transmission Problem? Need Help
  10. Tranny noise might be addressed
  11. Stillen g37 dual exhaust system
  12. Depressing clutch all the way or half way
  13. Clutch dead at 6.3k miles
  14. Enginte cut-off at 6200 RPM
  15. Clutch Getting stuck on the ground!
  16. check engine light at 500 miles
  17. For those of you who do your own oil changes..read up!!
  18. AC Questions
  19. Grounding kit. cant decide
  20. Odd Tapping On Startup? 6MT
  21. ECU which is best?
  22. G37 reflash in North Florida or around NYC?
  23. HFC installed- will void warranty
  24. Oil change questions
  25. Service Engine Soon light
  26. G37s With Ticking Noise From Engine
  27. Stillen Crank Pulley
  28. Exhaust Depot!
  29. Anyone got any feed back re: Pulstar pulse plugs?
  30. Transmission Question Auto/ Manual Mode
  31. Lower temperature thermostat
  32. Synthetic Oil
  33. ECU reset vs. ECU reflash
  34. Fluid leak at rear axle side flange
  35. Octane boosters!
  36. grounding kit on a 6mt
  37. Can I take my car to a Nissan dealership for an oil change?
  38. 15,000 Mile Service
  39. service engine light at 800 miles?
  40. Has anyone had the VVEL actuator TSB repair?
  41. How to Launch 6mt???
  42. IOS Performance????
  43. injen intake and FI exhaust
  44. 87 Octane
  45. Redid Dyno for Baseline
  46. Few mods and dyno to share
  47. Car Dyno'd today
  48. Any other performance options on the horizon
  49. Finally a REAL Jdm exhaust!
  50. TT on late model sedan
  51. ECU reset needed?
  52. Does anyone knows how i can find the ECU part # withut takeing the car to the dealer
  53. VDC, SLIP, 4WAS lights come on while driving?
  54. had problems with my G tonight :(
  55. Opinions on Dynoing the Injen Intakes... Need opinions...
  56. Installed Stillen Grounding Kit
  57. Power Loss Problem Solved??? - VERY Strange....
  58. Excessive water dripping from A/C
  59. Dyno g37s
  60. Oil Consumption Issue cured with G37?
  61. Manual Question
  62. Stock Intake Filters
  63. VDC frustration
  64. I Got a couple Questions (look please :))
  65. Whats the most exotic sounding MUFFLER not exhaust?
  66. Break In Period?
  67. Grounding Kit
  68. 15,000 mile service
  69. TEST PIPES or HFC'S??
  70. Hyper Voltage Gt? vs Grouding Wires
  71. A thought about Intakes and ECU for the G37
  72. My G Got Operated On (success)
  73. Newb Question about HKS F-Con V Pro
  74. Y pipe vs X pipe....
  75. anyone using pulleys yet?
  76. Car not the same AFTER ECU TSB reflash :(
  77. Clutch Question
  78. air intakes for g37S
  79. Service Engine soon light came on
  80. strange voice
  81. nitrous ne one???
  82. Sould i delete resonator with stock exhaust?
  83. infinti to pay for part of aftermarket cat back
  84. Engine cover question.
  85. DS > MM > D 5AT blows
  86. G37 turbo question
  87. Unichip or other piggyback chip
  88. synthetic oil
  89. Mobile 1 Oil
  90. Is this a joke
  91. Where is your RPM when going 50, 60, 70, and 80 mph?
  92. Question about manual shifting the 5AT
  93. Cobb tuning needs help from someone in the Salt Lake City Area
  94. ECU Toast at 1300 miles
  95. Dyno'd my G37 @ ZCarGarage
  96. Hks Camp 2
  97. braking problem and cracking noises.
  98. Idle RPM high and SES light on
  99. Engine idle issues when stopped
  100. Technosquare Article in July Import Tuner
