PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
  1. Question about adding paddle shifters to G37 sedan
  2. Fluid Change
  3. PST Carbon Fiber Driveshaft 7spd AT Coupe
  4. Wierd Transmisson Issue
  5. Can 2010 S coupe use the engine of 2009?
  6. Help Need help in OEM part .. Transmission filter!
  7. G37s coupe questions
  8. G37 AWD Upreved/Dynoed. Is this right?
  9. HFC related questions
  10. 5AT to 6MT
  11. Aluminum driveshaft paired with 4.08?
  12. Help not coming out of park gauges not working
  13. Performance Mod Suggestions needed G37x sedan
  14. VLSD on AWD G
  15. Car slams into 1st gear
  16. Looking at GTM TT kits
  17. Can traction control be turned off fully?
  18. Slow start...
  19. Need help bleeding clutch line
  20. The dreaded codes.
  21. Inspecting transmission, motor and diff mounts
  22. belt need to clean or change. ..
  23. Paddle shifters vs. floor shifter performance.
  24. G37s System Exhaust
  25. I'm hearing a weird sound every time I change gears
  26. oil consumption?? unsure whats going on...
  27. Issue with bogging down
  28. spark plug cost
  29. Help 6mt pumpkin swap driveshaft options.
  30. Engine Bay Temperature
  31. Help Lifter Tap
  32. Takeda Cat BAck
  33. anybody met this question in tuning throttle ?
  34. Car is shaky from Take off
  35. Tune up?
  36. White line bushing
  37. Clutch Pedal Play Changes Over Time?
  38. Problem with high idle/RPM spikes
  39. Stock Y-pipe?
  40. Dei reflect a gold heat resistant tape for metal intake
  41. Sea Foam'd my G - Smoke Show Video
  42. Mods before tuning
  43. Help Lets talk Oil coolers
  44. Car wont shift into gear
  45. Dumb question.
  46. 6MT No Reverse ???
  47. RJM clutch pedal voids warranty?
  48. Help JWT Clutch install....situation
  49. G37x non S , Possible to install paddle shifters?
  50. 5at to 6mt swap?
  51. Uprev throttle tuning
  52. Review Intake & Tune - Let's see how this goes....
  53. 7AT Transmission RPM Drop During Acceleration
  54. ARK Grip Performance Aftermarket Exhaust System | Infiniti G37 G37x G37s
  55. G37S Transmission Question
  56. Stillen G3 ultra long cai
  57. Help HFC VS TEST PIPE HP difference
  58. Valve Train Noise Cured? New Pennzoil Ultra Platinum
  59. Idle problems after stillen intake HELP
  60. Exhaust pls help
  61. Nitrous activation
  62. Need input on diagnosing P0300 Issue
  63. Anyone tried adjusting your clutch?
  64. anyone put 6mt 3.69 gears in 7at
  65. Pearl, G37xS Coupe Build
  66. Wheel Bearings replacement
  67. new vlsd diff going in
  68. Looking for suggestions of HFC or RHFC to pair with Stillen Catback
  69. Hard start when engine is warm
  70. Warning lights dim on cold start
  71. Done: 4.08 gears in a 2012 AT Coupe. But wait....
  72. horsepower question
  73. ATF Drain and Fill Help, Fluid Spec
  74. cluster part number
  75. Using Synthetic Motor oil on a high milelage G
  76. New CSF 370Z Radiator!!!
  77. G37 Drag while coasting/ fast deceleration?
  78. Anyone have any experience with a light weight flywheel on their 6mt?
  79. need some advise..
  80. Stillen Exhaust G37 Sedan 7Speed Auto
  81. Tired/Hot engine?
  82. Clutch Feel - new slave cylinder
  83. Slow Throttle Response
  84. Review OS Giken Grand Touring Clutch
  85. Z1 Motorsports Clutch Concentric Slave Cylinder Elimination Kit for the 6MT
  86. Hanging RPM's
  87. Transmission Programming after ITB-027D
  88. Is this noise normal?
  89. 6MT Clutch Chatter
  90. Rattling noise.
  91. Help P2122, p2123 app sensor
  92. Problem with clutch pressure and CSC?? HELP!
  93. G37 engine question
  94. Top Tier Gas
  95. Where to get an Uprev tune PA/NJ/NY area any recommendations?
  96. what is idle rpm reading?
  97. To tune or not to tune
  98. Seeking Advice on 5th gear grind/6MT questions
  99. Is the 5AT or the 7AT better in regards to TT
  100. Please help! Acceleration gone?!
