PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
  1. Help 10 g37 coolant loss 77k
  2. Help Broke a part while removing air hoses - what is it?
  3. Oil Pressure Questions
  4. About to get bolt-ons and tune, is the Z1 upper intake manifold worthwhile?
  5. Car rolls when parked on a snowy incline
  6. Stage 4 comp clutch and LW FW install
  7. VVEL Module - no throttle response / limp mode
  8. DOT 4 for clutch fluid instead of GTR brake fluid?
  9. Knocking from engine @1500 RPM & Above
  10. Relearn procedures with an Uprev tune
  11. Help Crank pulley installation. EM not clear
  12. Help Chipped gear tooth
  13. Drive Train Vibration
  14. Help G37X 2011 Sedan - Limp mode + code
  15. General mounts questions
  16. CV axle popped out - G37x coupe
  17. Need help with my build
  18. Help Total Transmission Faiulure - 7AT
  19. Hi end shifting
  20. G37x Sedan AWD Performance at High Speeds in icy conditions?
  21. Questions about Manual Mode in G37x
  22. Strange sound on cold start
  23. New Engine Bad Alternator
  24. Shifting problems
  25. Z1 differential bushing install question
  26. OEM header question
  27. MPG goes down
  28. Not another oil thread - oil brand comparison
  29. Advice Needed
  30. Oil pan gasket replacement
  31. 7 speed auto with 3.69 differential rpm question
  32. Motorvate Sneak Peek: "Ultimate Air Filter Flow Test"
  33. Upper radiator hose replacement
  34. Help galey gaskets
  35. Replace Water Pump[ at 87,000 miles?
  36. 2010 G37 running lean
  37. Motul vs Redline gear oil for differential?
  38. white smoke with sweet smell on cold starts
  39. Transfer case snapped where driveshaft meets. Need advice please
  40. Center Bearing on Main Drive Shaft
  41. Help High Speed Vibration
  42. 2009 G37 02 sensor bank 1 sensor 2 connector came apart from engines side
  43. is a Tune worth it with a stillen gen 3 and sports muffler?
  44. Long tube vs short ram intake dyno
  45. Help Engine Knocking Sound
  46. 2011 G37 transmission problem
  47. Help is there any OBD2 wiring behind the stereo?
  48. Another Coolant Hose Leak w Oil Stain
  49. Rough idle
  50. Throttle Response + Service Engine Soon Light + VDC Slip Light + The Snow Button
  51. 60k miles G37X Issues
  52. Engine knock on hot crank only, passenger side
  53. Help 09 G37S 6MT, Possible Clutch Issues
  54. Engine Overheating - Coolant leaking from engine - water pump ?
  55. Planning to get a Turbo, what engine modifications should I make first?
  56. Best Clutch for Daily Driving/Street needs?
  57. Oil Sandwich Plate Recommendations?
  58. Anyone with 7AT and 4.08 gears...
  59. VLSD 3.692 swap into a 2012 G37XS SEDAN open diff
  60. Help P2A00 code.
  61. Car Wont Shut Off!!
  62. Service Center Issues!
  63. TCM/ECM updates associate with ITB13-019a and ITB13-056a
  64. Won't stay in gear
  65. Who has the highest HP G here?
  66. Won’t start after Ignition Coil and Plug replacement
  67. Help P0011 and burned 3qts oil in 1 month
  68. G37 Oil drain plug slight leak?
  69. Please Help - Transfer Case Flush
  70. 08 g37s 2jzgte swap?
  71. ShiftLock fix (if anyone needs)
  72. Help Vq37hr crankshaft in to vq35hr
  73. Infiniti - X-Pedal Pro Throttle controller (7AT)
  74. 2013 G37X Wants to stall or loses power when on steep uphill
  75. Transmission flush complete!
  76. Where to buy paddle shifter kit
  77. Mysterious G37 Engine Bay Noise (Noise attached)
  78. Help When push to start, G37S *sometimes* cranks a while then turns over
  79. Nitrous specialists *chime in please*
  80. Octane booster royal purple test
  81. Help G37x Radiator Flush
  82. Help Car Stalled In Reverse
  83. Oil additives? Motorkote!?!
  84. 2009 g37x ~152k
  85. Q50/60 Shift Knob
  86. Sedan not Starting
  87. P0300 / C1109 CEL solved
  88. Motorvate DIY Video: 1 Year Update after $20 Diff Bushing Fix
  89. 2011 G25 misfire after spark plugs replaced
  90. 2008 g37 gtm twin turbo kit
  91. G37 needs cooling fans replaced
  92. Car can't rev and no acceleration at all
  93. Sound coming from the engine
  94. Help "service engine soon light" after HFC and CAI install
  95. Total Loss of Power
  96. Idler pulley bolt sheared
  97. Weird Clutch Engagement
  98. Engine wire replacement
  99. Ingen X-Pedal Pro Throttle Controller
  100. 08 G37 Coupe Issues
