stillen bov location?
Old Jan 20, 2015 | 12:12 PM
ceez06's Avatar
ceez06
Hello everyone couple months ago about a g37s that came with
A stillen supercharger, I want to put a turbosmart
Bov . I was told it's easy to install but Ima noon and
Dont know where it's located on the kit .
Stillen told me it's not a direct swap that I need custom
Work to put on . After asking a lot of people they
Told me there's no mods needed ....someone can help me out I'm in los Angeles .
Old Jan 20, 2015 | 01:04 PM
ANMVQ's Avatar
ANMVQ
Hey Cesar
If right in front of the radiator . : )
Attached Thumbnails stillen bov location?-97597d1417630274-first-stillen-supercharger-370z-swiss-p1000786.jpg
Old Sep 13, 2015 | 08:48 PM
perez519's Avatar
perez519
Originally Posted by ANMVQ
Hey Cesar
Quick question about this BOV how much did you adjust yours? by opening to soft or hard setting???
Old Sep 14, 2015 | 09:50 AM
perez519's Avatar
perez519
Hey Cesar
Correct me if im wrong, but looking at their website manual isnt this installed backwards? The boost side (inlet fitting) which is across from the top cap/ vacuum nipple should be attached to the longer hose connected to the inlet boot of the blower. The exhaust side (plumb back fitting) which is across the trumpet should be attached to the short hose connected to the charge pipe.
http://www.turbosmart.com.au/wp-cont...t_DualPort.pdf
Old Sep 14, 2015 | 04:39 PM
ANMVQ's Avatar
ANMVQ
Not sure whos pic I grabbed dont remember, Mine was long gone by the time I posted this. Just location , not how to hook it up
Old Sep 14, 2015 | 09:46 PM
perez519's Avatar
perez519
Sounds good So can you verify the instruction/picture I found on their website is that the correct way to install it? The reason I'm asking is I installed it backward the first time and my car keeps stalling out on gears and idle. Once I found this instruction and followed how to hook it up and adjust it run better. The car still need a final tune btw it only has base tune now.
Old Sep 15, 2015 | 10:55 AM
ANMVQ's Avatar
ANMVQ
Yes man, it is correct, If ever have questions you can test it yourself with the instructions. The boost pipe will always got the port where you can push the diaphragm in . The pic in link in your post is correct.
Old Sep 15, 2015 | 12:25 PM
perez519's Avatar
perez519
Thanks
2012G37
Intake and Exhaust
43
Jun 12, 2024 10:35 PM
4DRZ
Engine, Intake and Exhaust
12
May 18, 2017 11:25 AM
Simm0nS777
Sep 24, 2015 08:19 PM
