Our compression ratio vs boost?
Old Jan 17, 2015 | 01:51 AM
camry90's Avatar
camry90
How come I've not seen any body saying that you need to change to lower engin compression before going for FI?
Isn't 11:1 too high for any non direct injection engine to handle boost?
Old Jan 17, 2015 | 02:17 AM
604gz's Avatar
604gz
hey camry90 i have been wondering that same thing but never questioned it? My G is twin turbo on stock internals always ran at 11.4 pounds now for the last 4 and a half years. my first car was a integra and the rule of thumb i was told while building my engine was lower compression is better for FI purposes
Old Jan 17, 2015 | 10:30 AM
Glover998's Avatar
Glover998
It's not high at all.. it depends on the boost you're going for .. stock compression is just fine for a stage 1 setups or as long as you keep the boost in a resonable level .. type of fuel is also play a role here.
However, changing compression to lower level will give you the ability to boost the engine even more = more power.
Old Jan 17, 2015 | 09:24 PM
604gz's Avatar
604gz
Now i know why
Old Jan 27, 2015 | 10:38 AM
G37Xtreme's Avatar
G37Xtreme
Whereas 11.4 pounds of boost would be considered low for the Mitsubishi Eclipse which I think ran a lower compression 8.5:1 radio. IIRC, people would run up to 20lbs (maybe more) on these cars with massive turbos.
Old Feb 1, 2015 | 10:26 AM
ANMVQ's Avatar
ANMVQ
True I ran 24 psi on my stock 4G63 ( EVO 8). You'll never see that on a G with out 10k at least in the motor.
Old Feb 1, 2015 | 01:33 PM
vqsmile's Avatar
vqsmile
Besides the ability to run higher boost levels, running lower compression allows you to to also run more timing, which allows you to make more power. You can always boost a higher compression engine, but you'll likely have to pull some timing to avoid detonation, and hence will not be able to make as much power as you could have if the compression was lower.
Old Feb 2, 2015 | 01:48 PM
Magowin's Avatar
Magowin
Yeah I ran 24 psi on my stage 2 Sti.
Old Feb 5, 2015 | 09:35 PM
G37Stampa's Avatar
G37Stampa
Stock compression built turbo motor. Running 13.5psi for now on Q16
Victory
17
Oct 27, 2022 03:45 PM
goredcar
Mar 22, 2016 05:50 PM
Slapshot1
Sep 27, 2015 08:40 AM
