Changing front differential fluid, ended up snapping something. What is it?
Old May 4, 2018 | 07:02 PM
Dan G37's Avatar
Dan G37
Looks like some sensor
can anyone tell me what I broke and how to replace it? Thanks in advance!
Old May 4, 2018 | 08:39 PM
GdaddyNY's Avatar
GdaddyNY
Looks like your oil pressure sensor. Is your oil light on when you start the car?
Old May 4, 2018 | 08:42 PM
Dan G37's Avatar
Dan G37
Originally Posted by GdaddyNY
Kinda hard to tell from the pics, but it may possibly be your power steering pressure sensor. It’s definately a pressure sensors of some sort. It just threads out where it sits
Let me mark it so its easier to see. Is this a serious problem or will I be fine driving it around for a little while? No check engine light on.
Old May 4, 2018 | 08:44 PM
Dan G37's Avatar
Dan G37
It connects to the oil filter housing.
Old May 4, 2018 | 08:46 PM
Dan G37's Avatar
Dan G37
No light currently on when car is started. I think its the oil pressure sensor as well. The plastic fitting completely snapped off when trying to unbolt the Front Diff fill Plug.
The wire must have been in the way and the plastic fitting snapped.
Old May 4, 2018 | 09:23 PM
Dan G37's Avatar
Dan G37
Its the oil pressure switch, I went ahead and ordered an OEM replacement, thanks for the help!
keithnellie
Oct 2, 2022 06:08 PM
pincheseyha
Oct 11, 2020 05:37 PM
Calg37USMC
Aug 22, 2020 03:10 PM
doublea88
Jun 28, 2018 11:28 AM
GthangOrNoThang
Jun 14, 2018 08:44 AM
