I went thru the same thing few months back - squeeling loud at cold starts and then it would be quiet when the engine gets warmed up. Changed my belt since it was over due but it didn't help - Next was Power steering Pump - Replaced that with no luck - The squeeling noise wasnt as bad after I replaced my pump - flushed my steering fluid and radiator fluid the same day but still no luck with the squeeling noise.
and then one day it just automatically went away - Its been 3 weeks I havent heard that noise lolol
Not sure what this is but all my friends with the G37 made the same noise for few days when it was extremely cold.
Not sure what t F its all about
I haven't even replaced the belt yet but the noise has stopped ever since it got warmer out. I'm still going to replace the belt. Did you change the belt yourself?
^ Interesting! might use that belt when I change it next. I just replaced mine with the regular Gates belt.
On a side note, anyone wanting to replace the smooth idler pulley will have a hard time finding the correct part. The bolt on the Gates smooth pulley is too small. Looks like the other brands follow suite. OEM and the one from Z1 might be the only correct ones. Ended up using the factory washers, spacers, and bolt. The grooved pulleys from gates were fine.
