Stillen 19 row oil cooler
Old Apr 30, 2018 | 12:46 AM
Dtyler's Avatar
Dtyler
I just purchased the 19 row oil cooler from Stillen... It came with instructions. Was wondering if you guys have a DIY for it? It says to disconnect the power steering cooler and relocate it. Do I have to bleed it afterwards, and if so...How do I bleed it to get the air out the system? Also, I would pour an extra 2 and a half qtz of oil too right?
Thanks for the help!!!!
Old May 1, 2018 | 02:27 PM
RMB5190's Avatar
RMB5190
Google:
'Stillen oil cooler install + Z forums'
You'll get more than a few walkthroughs.
Old May 1, 2018 | 03:42 PM
slartibartfast's Avatar
slartibartfast
The power steering system moves a lot of fluid and the reservoir is the high point of the system. It should be self-bleeding.
Old May 2, 2018 | 04:50 PM
JaE35's Avatar
JaE35
You don't have to mess with the PS cooler...there's still room to mount the cooler. Take the bumper off and get creative. I have the same setup
Old May 2, 2018 | 05:16 PM
Baadnewsburr's Avatar
Baadnewsburr
Bleeding the PS is super easy after refilling just turn your wheel fully to the left and right a few times and add more fluid if it gets lower which it should only get marginally if at all...or do nothing and top it off after a few days if its a little low after the refill as it will have bled itself after few days of driving
Calg37USMC
Aug 22, 2020 03:10 PM
RickyBobby
92
Feb 26, 2020 01:45 PM
sweltman
Jun 2, 2018 10:13 PM
jk315
May 24, 2018 05:21 PM
