Master/Slave cylinder or both??
Old Mar 5, 2018 | 09:22 PM
Huaniitoo's Avatar
Huaniitoo
So I recently put a stage 2 clutch kit from ZSpeed with their HD slave and after installing it car was running fine till a day after I notice there such little pressure on my clutch pedal. I stopped driving it till I take it back to the shop but my question is. I didn't replace the master cylinder (I know I should have) but did upgrade the slave. If it's my master cylinder that's bad will the slave go bad with it as well ??
Old Mar 6, 2018 | 03:01 AM
JSolo's Avatar
JSolo
Just say no!!!!!
It's my understanding a master fails when it can no longer generate pressure. Usually due to seal wear. As the seals wear, debris contaminates the fluid. This is why it's a good idea to periodically flush/bleed the fluid.
In your case, if the master is already worn, bleeding becomes more difficult. I doubt there's damage to your slave unless it was installed improperly and/or damaged during installation. A new master should resolve the bleeding issue and bring back a firm pedal. Another thought is perhaps the new clutch requires more pressure and because the master is worn, unable to provide it, and/or air in the line.
I'd start by a thorough bleeding. Gravity bleeding works well, then finish off with traditional bleeding.
Old Mar 6, 2018 | 08:10 PM
saywat?'s Avatar
saywat?
do yourself a favor and get a 370z mc if youre going to replace it
Old Mar 6, 2018 | 08:58 PM
Huaniitoo's Avatar
Huaniitoo
What's the difference between both ?
Old Mar 6, 2018 | 09:14 PM
saywat?'s Avatar
saywat?
the z mc doesnt have this round disk on the bottom like the g does which makes install/uninstall a pain in the *** because it makes it stuck between the brake booster and brake lines. no one really knows what it does but speculates its a damper of some sort
911turbo
Mar 30, 2018 12:16 PM
D5074r
Feb 24, 2018 02:32 AM
