Changing the transmission fluid
Hey guys ,
i am an owner of a 2011 g37 with almost 95k miles i have the car now for 3 months , i have some transmission flares when changing from 4th gear into 5th gear and some rough shifts from 1st to 2nd to 3rd gear and , from 5th to 6th and 7th changes are smooth can't even feel the transmission shifting ,
so should i change the transmission fluid to Matic S since the previous owner said he changed the fluid before but with some other brand not the Nissan recommended fluid ,
some other question my ac doesn't work so should i replace only the AC COMPRESSOR or should i change the whole ac system ?Many thanks
If the fluid is Matic S compatible your AT should work well, quite a few of us have used Valvoline Max life Matic S spec, did mine 30k miles ago and is performing well.
If previous owner used a fluid that wasn't Matic S spec or didn't do the drain & fill as per the FSB then there surely could be issues.
I'd check w/ the dealer to see if your AT has the most up to date reflashes, and if you believe the ATF isn't spec or have doubts about the procedure he used, I would get it done again.
Heather Neyugn
Dec 25, 2017 01:41 PM
MotorvateDIY
Jan 18, 2017 01:31 PM
derekjl
Oct 17, 2016 02:35 PM
