Can Someone Post a D.I.Y. Oil Change for G37
Could someone who changes their own oil please post a DIY for an oil change with some pictures and what tools are needed. Thanks!
P.S. Don't move me
P.S. Don't move me
-Oil pan for oil draining.
-Drain plug is right underneath the oil filter.
-Oil filter wrench.
-Jack up car and take cover off.
-Take off oil cap and place rag over (so nothing falls in your heads
) -Unscrew drain plug with most likely 14 mm socket
-Drain oil till basically empty (better to do about 30 min after cars turned off)
-Insert drain plug with new copper crush washer
-Unscrew oil filter with wrench or maybe hand if it was put on properly
-You can or cannot (I always do) put a little new oil on the rubber seal of the new filter
-Tighten back on only HAND TIGHT! Do not use the wrench to put on!!
-Drop the car back level BEFORE putting the oil in. Or at least before measuring final oil level.
Wahlah! Done. If it wasn't 20 degrees hear and I didn't have engine parts and my Z all over my garage, I would post some pics, but unfortunately.....I have my Z and my engine parts all over the garage!
-Tools required should be a drive or Phillips to take off underneath engine cover. Maybe allen heads, but I doubt it.
-Oil filter wrench.
-Oil filter wrench.
The bolts under the car are 10mm, and omg there is more then 15, it was more like 20-25 bolts. There are 3 clips that pop off very easily with a flat head screw driver. The oil filter on my car was TORQUED like a mother from the factory, damn bastards put way too much on it. I needed a wrench from advance auto parts to get it off. The oil drain bolt was a 14mm.
Overall its very easy, just save yourself some time and use an automatic screw driver or drill and a 3/8 inch drive so you can take off those 10mm bolts quickly.
What kind of wrench; is it the regular oil filter strap wrench or the kind that goes over it like a cap/socket? I'll need it soon.
I just changed my oil at 1200 miles this weekend. I used the 18 dollar plastic ramps from walmart, which worked wonderfully.
umm. i'd be scared. lol
FYI... It was the socket/cap kind. I believe it was the 45-55mm one, but I can't remember. It was the smallest one they had and I brought in my new filter to test it.
My DIY is much easier.. drive to infiniti service, ask for 3750 service (basically oil change, lube and fluid/tire pressure check) grab a free cup of coffee, finding sugar can be difficult but it's usually there...then watch TV or play WoW on your laptop. 30m later pay $24.95 and say thank you and bye...
Level 100 Skill recommended before attempting this.
http://www.infinitiofcharlotte.com/S...s-Service.aspx
Level 100 Skill recommended before attempting this.http://www.infinitiofcharlotte.com/S...s-Service.aspx
lol, I can respect that. However I will never get my oil changed on my car. I've always been a car nut, I like to do every bit of maintenance that I can, on my own. Also, I wanted to go synthetic. It did surprise me, I noticed the car revved quicker with the synthetic in (rev in neutral or clutch pressed in). To each is own though, I've never had any car's oil changed for me in my life.
IF you down know then go about the long way and do each side a little or better yet, go buy some Rhino ramps.
