SPORT DS mode pros/cons
Old Nov 19, 2013 | 04:12 PM
itengineer's Avatar
itengineer
So, I've been enjoying the new G37 for a few weeks.
I just discovered the SPORT DS mode but not sure what the pros/cons are of using it.
Old Nov 19, 2013 | 05:13 PM
Yan141's Avatar
Yan141
U got yourself quick responsive throttle roar. But I rather on M mode all the time
Old Nov 19, 2013 | 05:14 PM
stockae92's Avatar
stockae92
Pro: better throttle response, holds gear longer
Con: visit the gas station more often
Old Nov 19, 2013 | 05:38 PM
RexHavoc's Avatar
RexHavoc
And how! I'm s
Down to 16.2 mpg but loving every minute of it!
Old Nov 19, 2013 | 07:29 PM
KEG97's Avatar
KEG97
Is the better throttle response proven?
I'm embarrassed to say, but I rarely drive in DS mode. Does that make me a bad G driver????
Old Nov 19, 2013 | 07:37 PM
ratso000's Avatar
ratso000
I drive in DS mode when in heavy highway and interstate traffic.When you put the cruise control on it also reduces the RPMs until you need the power: it will down shift more quickly to the lowest gear required to be efficent.I use DS most of the time for spirited driving conditions.
Old Nov 19, 2013 | 09:26 PM
DONTTASEMEBRO's Avatar
DONTTASEMEBRO
I can't tell the difference between D and DS other than the fact that shift points are higher...
Old Nov 20, 2013 | 11:14 AM
502GEE37's Avatar
502GEE37
DS ftw. Its additcitve
Old Nov 20, 2013 | 11:17 AM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
Well then it sounds like you CAN tell the difference between D and DS mode.
Old Nov 20, 2013 | 02:28 PM
blackfunk's Avatar
blackfunk
DS basically holds lower gears longer and downshifts sooner. All in All it makes the car 'feel' sportier. I don't know of any engine modifications as such by switching to DS mode.
Old Nov 20, 2013 | 04:17 PM
monty2003's Avatar
monty2003
Since my transmission update, my transmission downshifts aggressively during hard braking. I like this feature because it helps eliminate the lag that plagues many of us
Brian
Amrit.bhathal
Jan 29, 2016 08:56 PM
AMCDeac
General Tech Questions
Sep 19, 2015 05:25 AM
dholmblad
Sep 8, 2015 08:34 AM
