rev limiter
Old Dec 15, 2013 | 05:48 PM
omega13's Avatar
omega13
rev limiter
How high can we safely raise the redline on the 3.7 before valve float is an issue? 8k?
Old Dec 15, 2013 | 06:18 PM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
I've got a tune on my g37 and my tuner bumped the limiter to 8k. If you don't have a tune, I would keep it at stock levels.
Old Dec 15, 2013 | 08:51 PM
keraxis's Avatar
keraxis
Not worth it unless
Unless you have alot of bolt ons or FI... not worth it. 8k seems ok but listen to it. Thing is screaming. Most dynos show our motor falling flat at redline with a steady decline in trq. With a bigger turbo a higher rpm could help you stay in the turbo spool range and give you alittle longer in a gear.
Old Dec 16, 2013 | 08:30 PM
omega13's Avatar
omega13
fair enough, just curious. I moved my timing to -2 with my bullydog. I tried +2 but the car felt waay too rubber band like in the power delivery. It was like all the power was in the top. With it at -2 I feel more torque and the hp doesn't feel like it lost anything
Old Dec 18, 2013 | 07:11 PM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
unless you doing LTH not worth it
misc
29
May 24, 2023 03:57 PM
vamarris
Dec 9, 2018 11:10 AM
Sleepstupid
Oct 15, 2015 11:16 AM
xmajd92
South
Sep 28, 2015 07:22 PM
deky_
Sep 12, 2015 11:02 AM
