My G37 IPL Engline light popped up and I'm currently at 25k miles.
I wanted to know the best parts to buy for an oil change.
Via Oil Drain Plug Gasket, Oil Filter
Which oil do I buy I know i should buy the 5w30 synthetic oil but i don;t see a oil that specifically for cars under 25l-30k miles
Oil filter mobil 1 m110
Drain plug washer oem
Royal Purple, 5W-30 is also stellar and as a bonus, Walmart is now actually carrying it. There are many good filters, Mobil 1 is just fine. I went from Nissan synthetic to Mobil 1 to Royal Purple and RP was the only one that stopped the VVEL tick. Worked in my IPL and my QX70.
I'm curious on the initial diagnosis.
Flywheel wasn't aligned properly? How was that determined?
Is the flywheel junk?
How is the clutch pressure plate junk? Maybe get another disk and should be good. Resurface the flywheel?
