Help Valvebody and torque converter upgrade
Old Jun 13, 2017 | 05:51 AM
NoKaOi G37X's Avatar
NoKaOi G37X
My car is a 2011 X with Stillen Supercharger. Looking for some place close that can do the upgrade for the 7AT valvebody and torque converter like Level 10 does. I'm in Seattle so driving all the way to NJ is not possible. Shipping my car is $1800 to NJ that's too expensive. Any suggestions would be appreciated.
THANKS!!
Old Jun 14, 2017 | 03:45 AM
gearheadrd's Avatar
gearheadrd
You can have your mechanic to drop the transmission pan, pull the valvebody, and then send the valvebody to Level10 to do the upgrade. You can do the same with your torque converter as well.
Old Jun 14, 2017 | 08:21 AM
NoKaOi G37X
Thanks, sent them an email about that. Read a couple guys had issues with the ECU and TCM not communicating afterwards so I'd rather have a shop do all the work. Pulling the parts is my last resort.
Old Jun 16, 2017 | 02:42 AM
gearheadrd's Avatar
gearheadrd
You can send the entire transmission there for the upgrade, and it will still be cheaper than shipping your entire car there
Old Jun 22, 2017 | 05:40 AM
Mattlorentzoe's Avatar
Mattlorentzoe
THANKS!!
did you find a shop? I'm going this route and wondered if you had a review for us!
I'd love to know more about the torque converter before I pull the trigger
Old Jun 22, 2017 | 08:43 PM
Invaderzim's Avatar
Invaderzim
Here are some things I've read:
1. The 7at can be tuned by Seb at SpecialtyZ to hold torque for a supercharger up to 400ft. lbs.
2. Gears 5,6,7 can't handle the boost from a supercharger. The clutch packs are too weak. It will hold as long as you don't boost in these gears (what fun is that?)
3. Send it to Level 10 and it will cost 4000$ to bullit proof it. They install their valve body, better clutch packs, and a better torque plate. Maybe some other magic.
4. Buy the Exedy clutch packs, Level 10 valve body and billet torque plate from Fast Intentions and have a local guy install it. Still would have to have it tuned properly by someone. Might cost as much as just sending it to Level 10.
I may have missed something.
Old Jun 22, 2017 | 11:00 PM
Ape Factory's Avatar
Ape Factory
You've pretty much nailed it. I have heard it's easy to get the clutch packs wrong. Not sure if that's Level10 trying to get more work sent their way or what but it's definitely a job for a performance transmission shop and not your run of the mill place.
Old Dec 22, 2018 | 01:48 PM
Mattlorentzoe
Just wanted to say, this is exactly what i did. Almost 6 months on the trans. 8k miles or more.
-Level 10 valve body and 3k torque converter.
Also added exedy clutch kit for 7at.
Also added fast intentions flex plate.
Did a stillen trans cooler, but will be upgrading that to a 25 size row cooler from around 15 row size or so that it is now with stillen trans cooler. Ive had fluid changed 2x now with no issues. Multiple track sessions and drag strip passes. Also 8k or so miles put on, I’ve drove around the south east the last few months. Florida, Georgia,the Carolinas, Alabama, Tennessee, etc. Car is very much dailable but it is very aggressive shifting. Under $1000 labor to build trans professionally when you supply parts.
