Help!
I didn't check the spark plugs. It only have 38000 miles on it, I would thought spark plug won't go bad? Cold start is normal, only happen if I shut off the engine and let it sit for 1 hour then when I start the car this will happen.
I see the difference in the videos but don't see a problem. The engine doesn't stop in the exact same location each time. Both of these look like they're hot starts given the temperature gauge position. Heat soak, vapors, and other factors can affect start up.
Also, please use a more meaningful title next time. I often skip titles such as help or question or other vague terms.
