What spark plug is good for Infiniti g37
Old 11-11-2015, 08:41 PM
Jbunz
Jbunz's Avatar
Just wondering if anyone has changed their spark plug? Is there ngk for g37? Juss wondering thanks
Old 11-11-2015, 11:44 PM
Received 4,940 Likes on 4,174 Posts
NGK, Denso, Bosch all make G37 plugs, the Nissan OEM plugs are just fine unless you're running higher HP and need a different heat range. The OEMs are Denso Iridium 3457 plugs
Here's the OEM part #
https://discountinfinitiparts.com/pa...t=Spark%20plug
Old 11-12-2015, 01:36 AM
G37Sam
G37Sam's Avatar
The stock ones.
telcoman (11-12-2015)
Old 11-12-2015, 03:32 AM
JSolo
Just say no!!!!!
JSolo's Avatar
^^Agreed! Unless you're an engineer and truly understand spark plug design and how it affects engine operation, stick with stock.
Old 11-12-2015, 08:09 AM
telcoman
telcoman's Avatar
As others have mentioned replace your plugs with the OEM stock plugs
Here are my stock plugs from my previous 06 G35 with 106k miles on them
The stock replacement plugs were still on the vehicle when I traded it in with 171796 miles
Telcoman
Old 11-12-2015, 08:48 AM
Jbunz
Jbunz's Avatar
Telcoman
Oh okay I will so anyways where can I get the oem spark plug and if I get them from the dealership is gonna be expensive? What kind of ngk do u used? Thanks
Old 11-12-2015, 10:06 AM
Thirty_Seven
Thirty_Seven's Avatar
I ordered them from Rock Auto. It was the best price I found.
Old 11-12-2015, 10:20 AM
Jbunz
Jbunz's Avatar
Thanks but which one did u get the platinum or the iridium
Old 03-16-2016, 11:50 PM
xnick101
xnick101's Avatar
I didn't want to start a new thread for this dumb question but is the Denso FXE24HR11 pre gapped for our cars? Or do I have to buy the OEM one's that are in the Nissan box?
Old 03-17-2016, 02:50 PM
m3clubracer
m3clubracer's Avatar
Denso or NGK
Old 03-17-2016, 02:51 PM
xnick101
xnick101's Avatar
The denso's. Are they pregapped for our motors?
Old 03-18-2016, 02:53 PM
Kris9884
Kris9884's Avatar
I had the same question and searched everywhere and none of the manufacturers said they were pre-gapped. But if you search for a pre-gapped plug they all make sure to mention it so I'm going to go out on a limb and say no, you have to gap them to spec. Which is .044 with about .02 play room.
Old 03-19-2016, 09:08 AM
G37sGraphite
G37sGraphite's Avatar
Just read up on it...anyone can do it. You would want to measure and confirm them even if they are "pregapped". Most are not....
How to Gap a Spark Plug: 8 Steps (with Pictures) - wikiHow
Old 03-20-2016, 12:27 AM
xnick101
xnick101's Avatar
http://www.ebay.com/itm/252302835438?_trksid=p2060353.m2763.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Does anyone know if these are pre gapped since they are directly from nissan?
Old 03-22-2016, 04:41 PM
JSolo
Just say no!!!!!
JSolo's Avatar
Even pregapped plugs should be carefully checked and adjusted if needed.
Quick Reply: What spark plug is good for Infiniti g37
