Coolant Question
Coolant Question
I was checking my oil level and noticed the coolant level was low. The existing coolant is a blue liquid but coolant is generally a yellow liquid. I have used water as a temporary substitute. Does the G37 require a special coolant that I am unaware of or can I use the yellow coolant?
I hope you mean adding distilled water. Regular water does not get added to the coolant any more, only distilled. Typical tap contains minerals that will attack the aluminum parts of the cooling system causing premature wear.
How much did you have to add? I doubt adding a little will contaminate it much, but keep that in mind.
gdaelemans
Sep 15, 2015 12:20 PM
nbast
Sep 14, 2015 12:39 PM
