Oil temp/pressure Sensor/gauge
Old Nov 19, 2015 | 12:27 PM
PongSanity's Avatar
PongSanity
For the boosted folks out there. Where did you place your sensors; tap the oil pan, tap an after market oil spacer, a tee on the factory sensors, or a pre tapped oil pan spacer? Do anyone have a sandwich plate that's tapped for such purposes?
Old Nov 19, 2015 | 07:30 PM
bigc's Avatar
bigc
^ i replied to your post in the other thread:
https://www.myg37.com/forums/g37-cou...sor-ports.html
on my supercharged, then turbo'd DE motor, i installed the temperature sensor through my oil pan spacer and put the pressure sensor in a glowshift sandwich plate. the sandwich plate linked in the other thread has three 1/8 NPT ports so you could put both sensors there if that's more convenient.
Old Nov 19, 2015 | 08:46 PM
PongSanity's Avatar
PongSanity
I already got a sandwich plate for my oil cooler. Did you tap the oil pan spacer for the temp sensor though?
Old Nov 20, 2015 | 12:24 AM
bigc's Avatar
bigc
yeah, i ran a 1/8 npt tap through the oil pan spacer for my temp sensor. at the time, I wasn't planning on running an oil pressure sensor. had I known i would eventually do that, i would have just gotten the sandwich plate and wouldn't have tapped the spacer.
Old Nov 23, 2015 | 08:46 AM
PongSanity's Avatar
PongSanity
http://m.mishimoto.com/ystore/yhst-6...ich-plate.html
This plate also works.
Old Nov 23, 2015 | 09:54 AM
jwick's Avatar
jwick
Oil pressure I teed off the factory location cuz that is where I'm also getting turbo feed oil. Oil temp I bought AN fittings to tee in in the oil cooler lines (precooler). At the next oil change I'm moving my oil temp sender from the oil cooler to my new Phunk baffled oil pan as I had it customized to accept the sender.
Old Nov 23, 2015 | 09:56 AM
jwick's Avatar
jwick
Originally Posted by PongSanity
Do not use this. This sandwich plate cost a Z owner his motor for a bad o-ring that shipped with it.
Actually my tuner has a saying around the shop, 'friends don't let friends us Mishimoto crap.'
Old Nov 23, 2015 | 09:59 AM
PongSanity's Avatar
PongSanity
nice! that oil pan is bad a$$ ...
Old Nov 23, 2015 | 10:08 AM
PongSanity's Avatar
PongSanity
yeah i've heard about mishimoto and their o ring troubles. but if I replace the o ring with another of my own, wouldn't i be safe? For $160 i would've hoped they would have corrected that o ring nonsense by now...
Old Nov 23, 2015 | 10:24 AM
PongSanity's Avatar
PongSanity
theres also this one with 3 ports for oil return, pressure and temp but no ports for oil cooler...
Oil Filter Sandwich Plate Adapter, by Mishimoto
Old Nov 23, 2015 | 11:39 AM
jwick's Avatar
jwick
I would stay as far away from Mishimoto as possible. I know two guys that had their race thermostat fail. One caught it in time the other cost him his motor.
Plus if you are going to be running an oil cooler, you are going to want a thermostatic controlled sandwich plate.
Old Nov 23, 2015 | 07:04 PM
PongSanity's Avatar
PongSanity
I already have the stillen 19 row oil cooler with the thermostatic sandwich plate. Was checking to see what options the boosted folks in the G community did for their oil ports. I know how you did yours because I'm active in the370z.com site as well. Not much info over here. Could be as simple as running a second Tee to the factory oil sender as you did plus tapping the spacer.
Old Dec 14, 2015 | 09:54 AM
Mishimoto's Avatar
Mishimoto
Hi everyone! We did have an issue with a few of our rings in the past, however, we have redesigned the o-rings eliminate leaks as long as the plate is torqued properly. If anyone has a problem with oil leaking or seeping, please feel free to contact us at support@mishimoto.com so we can have replacements sent out!
Thanks,
Pat
Old Mar 2, 2016 | 08:57 AM
PongSanity's Avatar
PongSanity
Must've missed mishimoto response. Respect to those guys for clearing the air. I got the innovate oil temp/pressure dual gauge. In my Z1 spacer I'll tap my thermostat in then tee the pressure sender into the oem pressure sender which is the oil feed line for the boosted performance turbo kit. Just as how jwick did.
lippstuh
Feb 9, 2018 06:54 PM
jtspea2
Apr 1, 2016 03:52 PM
Mattlorentzoe
Nov 19, 2015 10:33 PM
ManDoo
Nov 18, 2015 02:44 PM
Detailed Image
Lighting/Cleaning Products
Nov 13, 2015 10:44 AM
