What's the best clutch for 2008 Infiniti G37s
My clutch is going out pretty bad, it's starting to slip and I have to let my clutch pedal more than halfway out to start moving. I bought a dual mass flywheel buy the company called "luk" all I need is to buy is my clutch, I'm just not to sure which one to get
JWT is a good choice as well as southbend for replacements also add a z speed concentric slave cylinder as well so you don't have any problems with the oem one
I want a clutch for street use but good enough where I could get power
You mean a clutch that will hold extra power you plan to add to the car in the future? Because most any clutch on the market is adequate for stock power levels and any bolt ons and flash tune you throw at it. The only way you'll need any additional holding power is if you plan to turbo or supercharge. The clutches that will hold up to this type of power can be used on the street, but they are not refined or comfortable for daily driving.
Almost anything. One that's an OEM replacement type. Stage 2 or 3 clutches or racing discs are just going to wear out your left leg unnecessarily and provide no extra benefit. Exedy. ACT. Spec. Southbend. These are a few. There's many more OEM equivalent discs that will do just fine.
Miguerosass (04-19-2019)
Running a Exedy OEM replacement on mine. Moderately stiffer and the flywheel isn't dual mass, so it's much noisier than Nissan OEM clutch. But Exedy is also significantly cheaper.
