Help No start in misty weather
Old Oct 30, 2015 | 01:03 PM
berts's Avatar
berts
Angry No start in misty weather
I have experienced two situations on my G37 where the engine cranks but does not fire.
They are about a year appart but during similar weather conditions. Both times it has been a light rain for several days.
During the one last year, the car was towed to a dealer and he got it started by resetting the computer(or so he claims). I proceded to have him clean out the throttle body and add a fuel injector treatment as a precautionary measure.
Just recently the same thing happens. Cranks but does not start. Same weather conditions.
Had it towed to a shop. No codes are present as measured with an OBD II.
The battery was down from trying to start it so many times prior, so he put a charger on it. Tried again and started as normal. Hasn't failed since.
What can cause this problem? Any thoughts?
Old Oct 31, 2015 | 05:24 PM
telcoman's Avatar
telcoman
You need the following when cranking the engine for it to start.
1- Spark Have you tested/checked for that?
2 If yes for #1 then check for fuel
3- If #1 and #2 are present check for air
Follow the troubleshooting steps in the FSM
Good luck
Telcoman
linvbro
Aug 22, 2016 01:25 PM
hooey_b
ECU Tuning / Dyno Data
32
Dec 27, 2015 09:10 AM
Sik Cajun
Nov 5, 2015 01:27 AM
sukhusukhu
Oct 15, 2015 03:56 PM
Victory
Car Care & Detailing
Oct 9, 2015 02:28 PM
