removal of TB coolant return
Old Nov 1, 2015 | 12:49 PM
hooey_b's Avatar
hooey_b
While i've been looking up how to do flex fuel conversion to E85, i've seen in some threads about ppl removing the coolant return lines to their throttle body...
i'm hesitant to do this; my main fear is lack of TB response in stupid-cold situations.
does anyone have any personal experience or input on the matter?
Old Nov 1, 2015 | 09:34 PM
conkus805's Avatar
conkus805
I don't have any info for you, but why would you need to do this for the e85 conversion? I'm converting my G to e85 and my tuner mentioned nothing of the coolant lines needing modification.
Old Nov 2, 2015 | 03:17 AM
takeapieandrun's Avatar
takeapieandrun
I only hear of people doing this who don't plan to drive their cars in cold weather. CA, AZ etc
Old Nov 2, 2015 | 10:36 AM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
im not sure where you have been looking up to do this..
but everything i have been reading about going to E85 is all you need are injectors and a tune!
Old Nov 2, 2015 | 11:35 AM
PongSanity's Avatar
PongSanity
There's a diy in the diy section. Makes intake Temps read lower. Real easy to remove. U shouldn't do this if it snows in your area.
https://www.myg37.com/forums/d-i-y-i...ypass-mod.html
Old Nov 2, 2015 | 12:24 PM
ttv36's Avatar
ttv36
Race, repair, repeat.
I did this because Texas and I have so much heat under the hood anyway. This definitely isn't needed for E85 conversion.
Old Nov 2, 2015 | 01:05 PM
hooey_b's Avatar
hooey_b
It was mentioned in a thread I was browsing thru. The guy said he did it since he already had the top half off installing the injectors, and I figured I could do it just to give me something to do.
I live in GA btw
Old Nov 2, 2015 | 01:06 PM
hooey_b's Avatar
hooey_b
^^he was going e85 and had a diy install for the injectors
mikysee
Sep 30, 2016 03:04 PM
hooey_b
ECU Tuning / Dyno Data
32
Dec 27, 2015 09:10 AM
00Max00
Nov 1, 2015 07:21 PM
dondb
General Tech Questions
Oct 30, 2015 02:15 PM
Randy Johnson
Intake and Exhaust
Oct 11, 2015 12:09 PM
