Engine hesitation?
Old Oct 1, 2015 | 11:26 PM
astat4's Avatar
astat4
Engine hesitation?
so for a while my car was having some hesistation when i would go heavy/medium on the throttle it was start hesitating. if i kept it WOT the CEL light would start flashing on me. looked it up and it blinks when there is a misfire. well i had a A/F ratio sensor code and i fixed ( loose pin) and that turned me CEL off. after that the car ran a bit better still hesitation now mainly after 5000 rpm. so i hooked up to cipher and everthing seemed to be fine. A/f ratio is ok, sensors are fine. o2 sensor take a bit to fluctiate but thats it. so i changed out my plugs and checked the gap for .044. and the car ran even better but STILL hesitation. idk what else it can be.
Old Oct 7, 2015 | 02:25 PM
astat4's Avatar
astat4
No one.?
Old Oct 7, 2015 | 02:39 PM
Victory's Avatar
Victory
Originally Posted by astat4
No one.?
Silly question, did you reset the PCM after fixing the AF sensor and doing the plugs?
Old Oct 7, 2015 | 02:56 PM
astat4's Avatar
astat4
Sill question whatsPcm.?
Hmm I haven't done a engine reset just checked for any codes to see if I had to clear or something.
Old Oct 7, 2015 | 03:05 PM
Victory's Avatar
Victory
PCM, ECU, ECM...whatever they're calling it.
http://www.6mt.net/forum/performance-mods/2833-easy-ecu-reset-procedures.html#/forumsite/20699/topics/2833?page=1
It's not a panacea, but at least it's free to try
Tuckermaclain
Oct 5, 2015 11:41 PM
claudiohv
Sep 17, 2015 01:43 AM
harlemcat45
Sep 9, 2015 09:35 AM
