Anyone running a surge tank with external pumps?
With two pumps dropped in my tank, my engine starves on strong right handers and on aggressive driving when the tanks anywhere below 3/4th's. I've recently fitted a fuel pressure sensor and confirmed it, fuel pressure drops to as low as 3 psi at times. CJM has no solution for that yet so I'm looking into an external surge tank setup, something like this squeezed in my spare tire area.
Anyone attempted anything like this?
Sam,
Look into this - GTM Motorsports
FUEL SYSTEM
GTM FUEL PUMP VOLTAGE STABILIZER KIT
then this - http://www.summitracing.com/parts/rci-7050a/overview/
Thank You and come again.
FUEL SYSTEM
GTM FUEL PUMP VOLTAGE STABILIZER KITthen this - http://www.summitracing.com/parts/rci-7050a/overview/
Is the feedback from the fuel pressure gauge blipping from high to low or is it slowly changing (lowering) as a result to driving more aggressive?
If it changes rapidly: Fuel sloshing
Slowly: Voltage
Slowly: Voltage
Yup it's rapid. I'd be coming out of a right hander with fuel pressure at a constant 47ish psi and as I start putting my foot down I get an immediate cut with immediate pressure drops, I make an aggressive left lane change and all the fuel goes back to where it should be haha
delfinparis
Nov 16, 2015 02:26 PM
