Loose paddle shifter on new '13 coupe sport.
Old Aug 1, 2013 | 03:59 PM
Damn Dirty Ape's Avatar
Damn Dirty Ape
Just got my '13 xS coupe almost 2 weeks ago and noticed the '+' right shifter is loose. Not loose forward and back, but vertically up/down. Probably 1/4" combined up and down. The left one has virtually no movement in this same way.
I called the dealer and they can look at it on Saturday - but like many others I'd rather tighten something up and check it than have a tech get in there. Seems like every time you take a car in there is something that gets messed up, scratched, on and on.
I found some info about the install and see what might be loose but looks like a bit of work.
Worth going into to see what's up? Much rather do it myself even though it's under warranty!
Old Aug 1, 2013 | 11:11 PM
AKG37's Avatar
AKG37
I have this on my '09, except my left side is a bit looser. I checked out a few different G sedans and coupes with the paddle shifters after noticing this.
Seems that no two cars are the same. Some were way looser than mine and some had no play. Must be the manufacturing tolerances.
I would suggest to not get it fixed, the cure will be worse than the disease (scratched panels, misaligned steering wheel, replacement not any better etc...).
Ultimately, it will come down to how bad you think it is and if Infiniti is willing to take a crack at it. I've left mine alone and it hasn't gotten worse in almost four years.
Old Aug 2, 2013 | 08:52 AM
ANMVQ's Avatar
ANMVQ
Mine are rock solid( Installed my own over a year ago) There are pretty simple to install just remove the lower cover and check the small srcews that hold them in place. One is just probally lose.
Old Aug 2, 2013 | 09:18 AM
sprix's Avatar
sprix
If you plan on keeping your car, there will be plenty of time to DIY. Enjoy having a brand new car with a brand new warranty. If I were you, I'd just take it back and allow the dealer to repair.
Old Aug 2, 2013 | 09:43 AM
Damn Dirty Ape
Difficulty of removing lower part without pulling steering wheel?
Old Aug 2, 2013 | 03:30 PM
Damn Dirty Ape
Using a few tips I found on here I was able to get the right side column cover off without removing much else. Yay me.
The nut and screw that hold the paddle shifter on and both tight. It appears the looseness is in the actual part that the shifter connects to in the little assembly.
That pretty much takes it from anything simple I can do and a warranty replacement by the dealer of the assembly I'd say. Agree?
Old Aug 5, 2013 | 12:15 PM
ANMVQ's Avatar
ANMVQ
YUP if the screw wasnt loose deal Warranty FTW
Old Aug 5, 2013 | 12:23 PM
Damn Dirty Ape
the screw and nut are not loose, showed it to them they are ordering a new part.
Old Aug 12, 2013 | 07:45 PM
rmfnla's Avatar
rmfnla
And that's why you let the dealer handle a car under warranty...
Old Aug 12, 2013 | 07:52 PM
Damn Dirty Ape
The problem with that is many times the tech will damage something in the process. Keeping in mind the shop manual calls for a steering wheel removal and I'd rather do it myself with warranty parts than have it pulled.
They are ordering another set, as the replacement was loose from the box, just a little worse than the original one. They have no problem with letting me swap it and I'd much prefer that. Now if the next one is loose from the box they want a area rep to see them. The G's on the lot are tight like they should be.
Old Aug 13, 2013 | 12:42 PM
rmfnla's Avatar
rmfnla
Talk to your service advisor and find out who the better wrenches in the shop are, and then ask for one of them to work on your car.
Old Aug 15, 2013 | 05:39 PM
lechner80's Avatar
lechner80
How hard was the install? How much time to do it? What parts where needed? (part numbers) and at what cost? Thanks John
G37xhibeet
Nov 15, 2016 09:29 AM
Pixel
Buying & Leasing
14
Oct 20, 2015 09:24 PM
R1 Dan G37
Sep 24, 2015 11:59 PM
joeposter
Sep 8, 2015 04:36 PM
