Active cooling on Stillen SC
I have an oprotunity to get a great price on a stillen sc. I am wondering if anyone has or know of an acticve cooling setup fot the water/air n-tercooler. I am not trying to start a GTM/Stillen debate, I have read the countless threads on the two, and the deal I am getting is great, just wondering about active cooling. If there is not product out, then I guess I have my next project.
Only thing you will need is the oil cooler, Trans cooler( IF auto) and uprev retune where they turn the cooling fans on earlier.. For the SC get a front mount heat exchanger. the one that bolts to the radiator I dont trust. I ran this on mine set up with some other mods and made GOOD power 467WHP
7 SPD X Coupe
7 SPD X Coupe
Thanks, I am have been preparing in stages. I already have an oil and tranny cooler, I want to get the VB upgrade before I install the blower also. I was just wondering about a better way to cool the charge air since I live in a hot climate.
You will not need the VB upgrade. I didnt run it and had zero shift issues. The line pressure can be increased with uprev.
The upgraded heat exchanger from frozenboost.com will work for sure, 24*7*3 is the one I ran. The only mod you will have to make is to cut the front tow hitch off.
Also make sure you have gauges to watch the temps
You can always install meth injection if you want a colder air flow. It will definitely help. That's what I have done, and the engine runs nice and cool. I also have the tranny and oil coolers and VB upgrade, which I highly suggest.
So would this be overkill Killer Chiller the Active Intercooler solution for OEM* and after maket intercooler systems.
timc00k
Feb 15, 2017 09:15 AM
RexHavoc
Oct 2, 2015 11:47 AM
SON415
Sep 28, 2015 05:49 AM
