Did Firestone overfill my g37 with oil?
This is the morning after I had my oil changed at Firestone with full synthetic 5w-30 oil. Shouldn't the oil be between the two dots and never over the H dot?
I checked like 6 times, wiped the dipstick each time with the same reading, oil over the H dot. I removed the dip stick normally, slowly and quickly, same reading.
Overfilled?
Overfilled?
You guys are making this a bigger deal than it is. Yes it's over filled. No it's not going to harm anything. Drive it hard or soft you'll be ok. It looks to be over filled by no more than 0.5qts.
0.5qts is not going to harm anything. I would not even bother trying to get it drained. Just leave it alone, it's fine.
Bommerang (05-20-2019)
I'd agree that it doesn't look to be overfilled enough to be concerned.
Can't fall out once it's been crossthreaded with the impact.
notalk
04-22-2009 03:23 PM
