Help O2 Sensor Wire - Any suggestions to fix this?
Old May 17, 2019 | 05:21 PM
GodlikeRage's Avatar
GodlikeRage
So,
Check engine light is on, code is throwing 02 sensor. I look under the car and turns out it got ripped off, literally wires are exposed, the end connectors aren't even there anymore. This sucks because that means I'd have to buy a completely new 02 sensor and new wire harness that wraps around the engine from what it looks like, unless any of you had any suggestions that I could do to circumvent this? This is for my 2009 G37s 6MT coupe sport. I wanted know if this wire is the same across all models, or all G's in general so I don't have to look for my year/make/model specifically. Is there a way I can solder these wires?
02 sensor and wire harness end connectors both cut off?
Old May 17, 2019 | 10:58 PM
Dzionassi's Avatar
Dzionassi
Solder it
Old May 18, 2019 | 07:05 AM
Conboss's Avatar
Conboss
I’d just take some spare wire hanging around the garage and solder it. No sense in replacing the harness if you can at least
make it work
Old May 31, 2019 | 04:05 PM
GodlikeRage
make it work
Are the location of the 4 colored pin terminals/wires the same as the other one?
cen_ice
Oct 27, 2022 08:07 PM
naresh.tj
Apr 20, 2019 10:47 PM
Woodlands Ed
Intake and Exhaust
Mar 27, 2019 03:06 PM
alecwatersmusic
May 19, 2018 10:30 AM
Ali6767
17
Aug 3, 2015 10:13 PM
