08 Infinitie G37 1500-2k rwhp build
08 Infiniti G37 1500-2k rwhp build
Hi, I own an 08 G37 coupe journey VQ37VHR 5 Speed A/T, and I wanted to make it an 1500-2000rwhp build in the future, I know it will take allot of time and money, such as making the block closed deck, completely upgrading the pistons, crank, and rods, valves, and cams and machining the head and bores, oh and upgrading the cooling system and tranny (idk if more should be done to the bores or not help?) I was thinking even after all of that I was wanting to go with twin charging it. And I was looking for suggestions and advice, was thinking of going with the bc Stroker 625+ kit. I was wanting to stick with the original block and just really upgrade it to handle the torture it's going to endure. It's allot ik but it'll be a bad mifo once it's done
The following 2 users liked this post by PNW_IPL:
Calg37USMC (06-15-2019),
jpowersjr2 (06-15-2019)
OP, as a auto technician that has seen multiple builds from Honda to Mercedes Benz and upwards to Lamborghini and Ferrari you will need at least $60,xxx for engine and transmission upgrades. We haven’t even began upgrading driveshafts, differential, drive axles, suspension, etc. On top of all of that your are boring out the original 3.7 to a 4.2L and will have to tune it. There are very few people who have went down the 4.2 rabbit hole and gave up due to fuel starvation issues and timing issues AND your are throwing forced induction into the mix? It’s not an easy road to travel but if you can pull it off you will be remembered.
GTM
130
06-05-2020 11:24 PM
firefox78
Buying & Leasing
18
03-28-2011 03:21 PM
