2012 G37x Engine vibration issues
Old Jun 22, 2019 | 07:57 PM
phace's Avatar
phace
My 2012 g37x has the check engine light coming on and the engine vibrating. My mechanic replaced the ignition coil, spark plugs and fuel injector, but the issue didn't go away.
I'm taking it to the dealers, but wanted to know if anyone has had this issue?
Old Jun 23, 2019 | 12:27 AM
slartibartfast's Avatar
slartibartfast
Gotta read the codes. No help can be offered without them.
Old Jun 23, 2019 | 11:41 PM
crookncastle's Avatar
crookncastle
what was the code that set the light? sounds like your guy just threw parts into it without knowing fully what is the root cause. ignition coils are pretty solid in nissan cars, usually the coil boots cause arcing when it has a crack or hole in it. fuel injectors rarely go bad, it does happen but in most vehicles fuel injectors are not a common part that just takes a dump.
Old Jun 24, 2019 | 08:31 PM
phace's Avatar
phace
The initial code was P0305, which is cylinder 5 misfiring. After replacing the ignition coil, spark plugs and fuel injector, that code went away and became P0300, which i understand is a general misfire code. He did some diagnostics today but came up empty, his next step is to get into the engine for an additional diagnostics. Any help is appreciated.
G37xsnewguy
Oct 31, 2017 12:06 AM
JGabucci
Dec 29, 2011 09:40 PM
EnviedG35
May 27, 2011 08:34 PM
groinkick
Dec 6, 2009 07:51 PM
Sha37
May 8, 2009 07:29 PM
