A/C Compressor replacement
Old May 18, 2019 | 07:31 PM
sharphawk's Avatar
sharphawk
My 2009 G37 Sedan's A/C Compressor just went out unfortunately, and the mechanic is charging $1,400 for the replacement including a 2 year warranty. However, I am probably not keeping the car for more than another year, (I'm at 150K miles) and do not need a super long lasting solution, so I'm thinking either an aftermarket compressor or a used OEM compressor. What do you guys think would be a better solution, a new aftermarket compressor like this or a used OEM compressor like this? Thanks for the help.
Old May 18, 2019 | 07:50 PM
ILM-NC G37S's Avatar
ILM-NC G37S
The estimate for $1400 seems way high. I would get a second estimate as the whole job is pretty easy. It is just a matter of:
1) recovering the refrigerant,
2) swapping out the compressor,
3) evacuating the system (deep vacuum) and,
4) charging with refrigerant.
It is a slightly time consuming project, but not at all labor intensive.
That said, if you are definitely going to be getting rid of the car I would go used. Just get one from a reputable seller.
That's just my thought.
Old May 18, 2019 | 10:45 PM
sharphawk's Avatar
sharphawk
Thanks for the response. What do you think of the used one in the ebay link in the original post?
Mrfudge
General Tech Questions
Jun 7, 2018 05:37 AM
DiamondGCoupe
Jun 10, 2016 01:13 PM
use2vw
Nov 23, 2010 11:38 PM
mindonmatter
Apr 8, 2010 06:11 PM
