Help FI-TT with UpRev tune: cranks but no spark nor fuel
Old Apr 29, 2019 | 01:14 AM
harbin9er's Avatar
harbin9er
Question FI-TT with UpRev tune: cranks but no spark nor fuel
Hey folks, I am running into a road-block with my install. Does anyone have an idea about this? thanks
I have a 2008 Infiniti G37S 6MT, which I am currently in the middle of installing a Fast Intentions https://fastintentions.com/ Twin Turbo kit for. The ECU tune was made by sebastian@specialtyz.com for this application using UpRev.
I have my own UpRev cable and license. After flashing Sebastian's tune into the ECU with UpRev's RomEditor, I can crank the motor, but it does not start. Below are the results of my diagnosis so far:
  • My ECU ROM number is: <23710 - JK75D>.
    However, Sebastian gave me a tune for " JK78C", but assured me that JK78C is the updated ROM and this is what UpRev has been using for my ECU for a few years already.
  • Checked all fuses - none blown
  • Checked all wiring harnesses- all OK and connected
  • The following were checked using both <Sebastian's JK78C tune>, as well as the 'OEM' <JK78C.OsirisROM>, which was downloaded with UpRev's RomEditor:
    • NO SPARK
      I physically checked this during cranking with an inline spark plug tester. However, there was 12V across two of the three terminals (the third terminal is ground, I assume) in the connector that goes into the coil pack - this would indicate that there is no physical wiring issue.
    • NO FUEL INJECTION
      I physically checked this by pointing an endoscope into an open spark plug hole, as well as putting a stethoscope onto a fuel injector to listen for clicks during cranking. However, I know the fuel pump works (it whirls up at key-on), and I do get fuel pressure (physically measured by fuel-pressure gauge) into the rails (there is fuel all the way to the injectors when I disassembled it).
  • Searching in internet forums, there were some similar 370Zs/G37s "crank, but no start" issues. They've found the problem was due to a bad crank angle sensor. However, I didn't touch the crank sensor during my install, but I did have to change to an aftermarket flywheel. Furthermore, I logged some data using UpRev's RomEditor and I do get reasonable Engine RPM readings (it goes up to ~150RPM during cranking). This seems to indicate it's not bad crank sensor.
Old Apr 29, 2019 | 10:48 AM
ttv36's Avatar
ttv36
Race, repair, repeat.
    • NO SPARK
    • NO FUEL INJECTION
Wow joining the boosted club after how many years? Welcome aboard the train brother!
Uprev lists their roms here: https://uprev.com/romlist.php
According to the list you did get the proper rom.
There could be a number of things, but I would say to double check all of the coil harnesses - make sure you haven't swapped cylinders 1 & 3 for instance. Also check the grounds and see if the coil packs themselves are still good and not shorted somehow.
Edit: Also check your starter lead wire from the harness or the main power wire to the starter.
Good luck!
Old Apr 30, 2019 | 04:00 PM
harbin9er's Avatar
harbin9er
Thanks! I actually started planning this turbo ~10 years ago I when I bought the car while I was still in grad-school. I needed multiple steps to happen before I could start on the install, though: graduate, get job, change job and move city, buy house with 2 car garage, get secondary vehicle so I can still drive while working on install.
UpRev gave me some feedback which I will check on tonight.
I'll also check on the wiring into the starter.
At this stage I think the issue might be some random, seemingly-unrelated wiring/harness/connector that I didn't connect/forgot
Old Jul 22, 2019 | 10:34 PM
harbin9er's Avatar
harbin9er
Turns out it was a mistake that I'm sure several people made before - did not install a dowel-hole on the flywheel, to the dowel-pin on the back of the rear crankshaft seal.
It's easy to miss because the pin is so small
the_wolff
Nov 27, 2022 01:56 PM
Paul_G37
Nov 28, 2020 06:49 PM
hockeyzbh
ECU Tuning / Dyno Data
Dec 29, 2016 11:40 AM
el_donks
May 16, 2016 11:33 AM
Dough1397
Feb 15, 2014 03:13 PM
