The transmission doesn't downshift and stick at 4000rpm in DS mode
The transmission doesn't upshift and stick at 4000rpm in DS mode
Greetings:
I just notice that in DS mode in my 09 G37x with 1000 miles on it, the transmission doesn't upshift even though I am already a hair above 4000rpm and at 90 mph. Is this normal?
I believe the OP meant it doesn't upshift (vs. downshift). Depending on how you're driving in DS mode, the TCU will hold the gear through much higher RPM although you would think it would upshift if you back off the accelerator. I've noticed the same thing on occasion in DS mode myself.
My apology for using the wrong terminology, I do mean "upshift" instead.
When in DS mode and start from a stopping point, the car upshift automatically as it reaches certain speed and rpm until it hit 4000 rpm at 90 mph. From this point on it doesn't seem to upshift to a higher gear and the engine sounds like it is in 5th gear. Since I haven't finished the 1200 miles break-in period, I am not sure if I can push the rpm higher to see if it will upshift or not. However I do try at ~4200 rpm for a short period and it still doesn't upshift.
DS helps when you want to pass some idiot going slow in the left lane with traffic on the highway too. I put it into DS when I am coming up on a gap in traffic in the right lane, then pass the moron, then go back to D when I am clear and just cruise until the next one.
