Motul 8100 Oil
Motul 8100 Oil
I keep reading about Motul 8100 X-Cess 5w30 in other threads but I can only find Motul X-Cess in 5w40. The only Motul 5w30s I can find is the Motul Eco-Nergy and Motul X-max. Which one should be getting?
Also do you have any recommendation on where to purchase these?
Thanks,
Jason
Thanks,
Jason
I'm using 8100 0w40 and it seems to be just fine. 0 is the viscosity when cold, and 40 is when hot. I bought mine from Forged. http://www.forgedperformance.com/
might wanna ask this in the "General Tech" thread since that's where car maintenance stuff is discussed....might get a bigger response. Just an idea! I personally want to know the answer to your exact question too since I've considered Motul 8100.
Except, the journals and passages are sized for a 30 weight oil, not a 40 weight oil. I asked a friend of mine who is a chemical engineer with a major oil company if I could use the 5W-40 synthetic I had been using with my previous car in the G37. His short answer was "no", because the engine is not designed for a 40 weight oil when hot.
Thanks,
Jason
Thanks,
Jason
