Notices
GT Motorsports: GTM Rear Differential Cooler Kit
Old 05-19-2009, 09:08 PM
GTM
GTM's Avatar
Exclamation GT Motorsports: GTM Rear Differential Cooler Kit
We would like to introduce our new differential oil cooler kit for all the hardcore enthusiasts out there. Heat is the main factor contributing to oil breakdown, and can lead to premature failure of your limited slip differential under extreme conditions. Traditionally a finned differential cover would be used but they usually only provide marginal improvements in cooling.
For the serious enthusiasts we have designed and developed a heavy duty differential oil cooler kit that will meet and go beyond your expectations. We know this modification isn't for everyone, but for the people that do need (serious road racing/drag/drift) we have it for you! This will also help extend the service life of your gear oil since it won't be getting as hot under extreme conditions.
We will have the basic cooler available as a standalone, with our aluminum shroud as an option. This shroud will help force air directly at the cooler, significantly increasing its performance, it also acts as a mounting bracket.
Another option will be a programmable temperature activated control unit which will control the pump to only come on once the desired temperature as been reached. This will increase pump life and avoid having the pump on when not needed.
**Purchase/Product information click on the images below:**
GTM Differential Cooler Kit:
GTM Differential Cooler Shroud Kit:
GTM Differential Programmable Pump Controller:
GTM is offline
Old 05-19-2009, 09:14 PM
Wezbian
Wezbian's Avatar
Wow this looks cool, but what about people who have the muffler in that general area? Do we need a twin canister type exhaust?
Wezbian is offline
Old 05-19-2009, 09:35 PM
GTM
GTM's Avatar
Correct you will need an exhaust that leaves the center section open, we also offer a kit with longer hoses so you can mount the kit however you would like. It can be made to work with both exhaust.
-George
GT Motorsports
GTM is offline
Old 05-20-2009, 08:40 PM
Budakai
You guys make some intense parts.
Budakai is offline
Old 05-23-2009, 06:37 PM
Q8y_drifter
Q8y_drifter's Avatar
they sure do!
Q8y_drifter is offline
Old 07-12-2016, 07:25 PM
sunshineskyler
Anyone know what inline filter that is/what AN size?
sunshineskyler is offline
Old 07-16-2016, 08:51 PM
Ape Factory
I can't really tell for sure from the photos but it's probably either an 8 or 10an line.
I'm also going to guess that it's made by XRP, possibly was a custom job for GTM.
Here's their catalog, check out page 47.
http://www.xrp.com/wp-content/upload...ct-Catalog.pdf
Ape Factory is offline
Old 07-16-2016, 08:52 PM
Ape Factory
I take back the XRP suggestion (although they have something that would work). The other fittings are Russell. Check there.
Old 07-16-2016, 09:28 PM
Ape Factory
sunshineskyler (07-18-2016)
Old 07-18-2016, 06:42 PM
sunshineskyler
Dude, nice find. I'm going to go with that one.
Old 08-09-2016, 08:33 AM
purpleharo
Does anyone have the fittings sizes for this? Im thinking would need 10mm x 1.25 to -6 and for the diff, then a reducer of -8 to -6 to go to to pump and same going back in? Thanks!
purpleharo is offline
Old 08-09-2016, 10:29 AM
Ape Factory
Are you using an afermerket diff cover like the one from Z1? If so, write to them and see what AN size the ports are. Is the pump definitely -6?
Old 11-03-2016, 01:22 PM
sunshineskyler
Yes the Z1 cover and used -6 for the trans cooler and diff cooler. Here's what the setup looks like.
Old 11-09-2016, 05:00 AM
Synolimit
Synolimit is offline
35Sport
02-02-2017 11:32 AM
Broski28
02-09-2016 11:50 AM
warpeacelove
09-28-2015 10:39 PM
G37S-K52
Southern California
09-11-2015 01:10 AM
Quick Reply: GT Motorsports: GTM Rear Differential Cooler Kit
Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
