Padlle Shifters on my 2010 Base G37 Sedan
Old Sep 3, 2012 | 06:06 PM
Mr.Brown001's Avatar
Mr.Brown001
I just installed paddle shifters on my base 2010 g37 sedan! Worth every penny! Makes the car a hella lot more fun to drive! But upshifts seem to be just as delayed as they were using the standard stick shift. Does ITB12-027 address this issue? And also I want to paint my stock 17s gunmetal and was wondering if anyone has done it before? Any pics?
Attached Thumbnails Padlle Shifters on my 2010 Base G37 Sedan-imag0028.jpg   Padlle Shifters on my 2010 Base G37 Sedan-imag0089.jpg   Padlle Shifters on my 2010 Base G37 Sedan-imag0093.jpg
Old Sep 3, 2012 | 09:54 PM
blazeplacid's Avatar
blazeplacid
how was the install?
I do my own car audio installs for my self and friends and feel confident I can do this.
Do you have to move the shiftier over to DS to enable the paddle shiftier or do you tap on the shifter and the car knows what to do?
Old Sep 3, 2012 | 10:57 PM
Mr.Brown001
Before I ordered the kit, I checked to make sure i had the connectors for the paddles, you should do that also, so you don't go through the hassle of buying the paddles and returning them. As for the installation, took me about 30-35 mins. Very easy and straight forward installation. Since you do audio installations, this should be a piece of cake.
Don't remove your steering wheel and airbag and make the installation over complicated, use the DIY from this website: Infiniti G37 Paddle Shifter Installation
Don't have to move to DS to use the paddles, you can use them while you are in D. If you are in D and use the paddles, it will switch to manual. Once you stop using the paddles for 5 secs, it will switch back to D mode. In DS, if you use the paddles, it will stay in Manual mode.
Hope that helped. Let me know if you need anymore info about the installation.
Old Sep 3, 2012 | 11:10 PM
BuckNorris's Avatar
BuckNorris
+1. cake with that DIY. at or under a half hour. well worth it. GL
Old Sep 4, 2012 | 12:03 AM
TheAmazingNik's Avatar
TheAmazingNik
+2 super easy no need for any removals except the paneling, just turn the wheel left and right you'll figure it out!
Old Sep 4, 2012 | 10:01 AM
91ZCpe's Avatar
91ZCpe
On the bottom, where the center trim piece is - does it stay securely attached to the side trim pieces?
I just installed mine 2 weeks ago and my trim pieces are loose on the bottom - like the snap pieces keep coming undone.
I either have to use tape to hold it together or push the steering wheel all the way in and it is secure.
Has anyone else seen this problem?
As far as delays - I wonder if the grouding kit would help? I've read that it is supposed to help with the delays..
Old Sep 4, 2012 | 03:24 PM
PENROSE's Avatar
PENROSE
Where to buy the kit? How much $$
Old Sep 4, 2012 | 03:26 PM
bluedevils95's Avatar
bluedevils95
You can call james at oc infiniti.
Old Sep 4, 2012 | 03:30 PM
DeepRumble's Avatar
DeepRumble
It's good to know you don't have to remove the steering wheel to install these. Gonna have to save up a little to grab a set.
Old Sep 4, 2012 | 07:58 PM
GhostFaceKilla's Avatar
GhostFaceKilla
Enjoy the paddles. Makes driving much more fun.
Old Sep 5, 2012 | 12:08 AM
Mr.Brown001
Ebay, 250$ shipped from Perry Infiniti. They shipped from Cali on Monday and I got it by Friday noon in Atlanta, Georgia. So pretty fast shipping.
Old Sep 5, 2012 | 12:18 AM
TinsleyC's Avatar
TinsleyC
It's the same shift - the same signal sent from the stick, just sent from the paddle, instead. It seems the same because... it is.
m3clubracer
Sep 11, 2016 09:01 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
JoshB
Oct 15, 2015 03:08 PM
maybeg37
Sep 8, 2015 02:33 PM
DevinKoolie
Aug 11, 2015 06:47 PM
