RHFC Rattle fix?
Old Nov 9, 2012 | 09:48 AM
Espig37s's Avatar
Espig37s
RHFC Rattle fix?
So I had a Fast Intention RHFC installed and now it rattles like crazy when I am idling. Besides having the stock supports being welded to the RHFC, is there any other fix? Would the rattle be a sign that the RHFCs are hitting the subframe or other part? Was thinking of wrapping them in high temp tape for exhausts to prevent the rattle, think that will work?
Otherwise, the power and the sound from the RHFC are awesome. Just need to fix this rattle...
Old Nov 9, 2012 | 12:14 PM
Espig37s's Avatar
Espig37s
anyone have other suggestions?
Old Nov 12, 2012 | 10:55 AM
Espig37s's Avatar
Espig37s
Can anyone provide any suggestion on fixing this rattle?
Old Nov 12, 2012 | 12:23 PM
ECain18's Avatar
ECain18
Check the cat brace. U might just need a new one. Its 25 bucks from fb parts i believe
Old Dec 15, 2012 | 10:16 AM
Espig37s's Avatar
Espig37s
The cat brace isn't used with these rhfc. Anyone else khabe any ideas of how to fix a rattle here?
Old Dec 15, 2012 | 12:23 PM
SharpByCoop's Avatar
SharpByCoop
You need to a little more homework:
What's rattling? The pipe against the frame, or the internals?
One is relatively easy, the other is not.
Let us know. No one can make suggestions if they have not experienced the same dilemma.
Coop
Old Dec 15, 2012 | 01:01 PM
Espig37s's Avatar
Espig37s
good question. Im not really sure. Hopefully its the pipe against the frame and not the internals. It appears when I am idling normally. I know I''ve read on here that the FI RHFC don't re use the stock cat brace and that some people have figured out a way to stop the rattle based on welding something to the stock braces. Figured more people had this issue.
Old Dec 15, 2012 | 01:36 PM
bluedevils95's Avatar
bluedevils95
I have the same thing. i know what your talking about. I was just going to go back under the car and see what i did since i installed it myself.
Old Dec 15, 2012 | 01:39 PM
Espig37s's Avatar
Espig37s
Let me know what u find.
Old Dec 15, 2012 | 08:58 PM
bluedevils95
Will do, did you install it yourself or did you have someone else do it?
Old Dec 16, 2012 | 01:32 AM
Purpul's Avatar
Purpul
I am very curious to see whats is causing the rattling as well
Old Dec 16, 2012 | 10:30 AM
Espig37s's Avatar
Espig37s
A shop installed mine...
Old Dec 17, 2012 | 05:05 PM
IPL 370GT's Avatar
IPL 370GT
This is actually the third owner in two weeks complaining about this. One local guy had the same issue that was pointed out during a summer meet. He's still having a problems with that exhaust.
Old Dec 18, 2012 | 05:19 PM
Espig37s's Avatar
Espig37s
What are you talking about?
This is a fast intention high flow cat, not some knock off.
Old Feb 3, 2013 | 09:47 AM
gojcgo's Avatar
gojcgo
Just curious if anyone found a fix for this? I'm thinking of jumping into a group buy on the FI RHFC but keep reading about the rattling issues.
Any insight would be appreciated.
