Weird whining noise.
Old Oct 26, 2012 | 11:17 PM
Tiny's-G37s's Avatar
Tiny's-G37s
Hey Guys, My G has a weird whining noise that sounds like it's coming from underneath the car. It's pretty loud on idle and you can also hear it in 1st, 2nd, 3rd and 4th gears when accelerating and driving. It's pretty bad. It goes away if you press down the clutch but comes back in if you release the clutch. I didn't want the dealer to take my whole car apart and then tell me they don't know what's wrong with it so i figured I'd ask you guys first. Is this fixable? I have a 08 6spd coupe with 21k miles if that matters. I took a video of how it sounds so you can see what I'm talking about. Here is a link to my video on youtube :
Old Oct 27, 2012 | 05:28 PM
juicybusa's Avatar
juicybusa
You have a bad bearing(s) in your transmission. Very obvious.
Old Oct 30, 2012 | 09:58 PM
akiradavis's Avatar
akiradavis
I had the same noise. Took it to the dealer and they found metal in the transmission fluid. They replaced my transmission under warranty. The noise is pretty much gone, you have to really listen to for it and it could be my imagination. So, take it to the dealer.
Edit: your car sounds worst. Take it to the dealer before you get stranded.
Old Oct 30, 2012 | 11:01 PM
canucklehead's Avatar
canucklehead
^+1. very obvious bearing issue. You will have no problem getting a warranty replacement.
Old Oct 31, 2012 | 01:51 PM
Tiny's-G37s
Will they give me trouble about my stillen gen 3 intake and y-pipe. Can they void the warranty because of that. Should I take the parts off before I bring it in to the dealer?
Old Oct 31, 2012 | 02:18 PM
Dawson's Avatar
Dawson
I would put the stock parts on as a precaution because I had a salesman tell me that if I brought my car in with aftermarket parts it would void my warranty but I've heard other guys take there's in with no problems
Old Oct 31, 2012 | 03:38 PM
canucklehead
those aftermarket parts will not void the warranty for a gearbox issue. only if the parts could negatively affect the defective part could they void it. i.e. if you had installed lowering springs and were claiming an issue with your shocks, they would likely not cover it.
there are plenty of threads on here about warranty concerns. and the Magnuson-Moss Warranty Act of 1975 is very clear about this.
you will be fine.
Old Oct 31, 2012 | 08:31 PM
Tiny's-G37s
Thanks for all your help guys, I'm gonna take it to the dealer.
Old Oct 31, 2012 | 08:49 PM
Tiny's-G37s
Does anyone no how the service is at Herb chambers Infiniti in wesborough, or at Harte Infiniti?
drewfinity
Nov 27, 2016 02:11 PM
Prometheus
General Tech Questions
Nov 9, 2015 01:23 PM
Slapshot1
Sep 27, 2015 08:40 AM
acthesquid
Sep 18, 2015 06:31 PM
acthesquid
Sep 15, 2015 07:31 PM
