Remove rocker covers?
Old Dec 21, 2015 | 10:07 AM
pwcracer's Avatar
pwcracer
Does anyone know how to do this? I am guessing there are hidden clips like on a door panel.
thanks
Old Dec 21, 2015 | 11:57 AM
VaderK52's Avatar
VaderK52
There are like 2 screws to remove from the inner wheel well area front and rear then like 4-6 underneath the rocker panel itself. They are easy to locate and yes there are clips but if you apply slight pressure when pulling they will pop right out. It's a very simple job just don't go yanking on it esp if you are not upgrading and plan on reusing the stock rockers later down the line.
Old Dec 22, 2015 | 01:39 AM
crookncastle's Avatar
crookncastle
thanks
are you referring to the valve covers?
Old Dec 22, 2015 | 08:39 AM
VIVID's Avatar
VIVID
Pyroclastic Flow
Vader's right on.
Check out the FSM in the Ext section, page 29:
http://www.nicoclub.com/FSM/G37/Coup...EXT.pdf#page29
Here's a shot:
Sean
Old Dec 22, 2015 | 10:23 PM
crookncastle
Originally Posted by VIVID
Vader's right on.
Here's a shot:
Sean
the op asked how to remove "rocker cover" not "rocker panel". i'm just wondering if he is referring to the valve cover?
Old Dec 23, 2015 | 08:12 AM
pwcracer's Avatar
pwcracer
Thanks for the great info. Yep, I meant the covers that attach to the rockers under the door.
pwcracer
General Tech Questions
Dec 10, 2015 04:19 PM
RickyBobby
Dec 8, 2015 03:36 PM
mcola
Dec 6, 2015 10:32 AM
00Max00
Nov 1, 2015 07:21 PM
Ace_withthetopd
Oct 31, 2015 04:50 PM
