6MT drivers with zero slave cylinder issues
Old Dec 23, 2015 | 01:18 PM
2009IPG37S's Avatar
2009IPG37S
I'm not here to jinx anyone but I want you guys to be heard that there are guys out there with zero slave cylinder issues with their g37s 6mt's.
I'll start
09 g37s 6mt
94k miles
no known issues thus far and knock on wood!
Old Dec 23, 2015 | 01:37 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Now you've done it!
Old Dec 23, 2015 | 01:57 PM
2009IPG37S's Avatar
2009IPG37S
May the force be with you!
Old Dec 23, 2015 | 05:21 PM
User 122320's Avatar
User 122320
I'll start
09 g37s 6mt
94k miles
When you shift gears, do you press the clutch all the way to the floor? Or just enough to engage the clutch? (went in for an oil leak, noticed a pool of oil on the floor).
I press mine all the way to the floor each time. Maybe that's why it failed at 2800 miles?
But, I think this is a known issue because the service writer noted that CSC had to be replaced before the techs even looked at the car.
Old Dec 23, 2015 | 06:19 PM
2009IPG37S's Avatar
2009IPG37S
I press the clutch all the way down to the floor before switching gears.
Old Dec 23, 2015 | 10:31 PM
User 122320
What about the CSC tube? Did you get those replaced? Those have been known to be a big failure. Even the 370Z guys go through those like nothing.
Old Dec 23, 2015 | 10:34 PM
2009IPG37S's Avatar
2009IPG37S
nope, doesn't need replacing? drives fine.
Old Dec 24, 2015 | 12:01 PM
2009IPG37S's Avatar
2009IPG37S
Wow, I'm the only one!?!
Old Dec 24, 2015 | 12:49 PM
xnick101's Avatar
xnick101
68k and still going on stock clutch and CSC. Fingers crossed! I beat on my car daily. Lots of drag strip passes as well. When the car had OEM fluid the clutch would slip a lot and would not grab properly. Switched to BG dot 3 brake fluid and have had zero issues since then. I change the clutch fluid every year as some members on here recommend. Also BG has a program where if you use their fluid and the part fails they will replace it for free or atleast cover 50%. Next year's project is to go turbo
Old Dec 24, 2015 | 12:54 PM
2009IPG37S's Avatar
2009IPG37S
very nice, is there a DIY on changing clutch fluid? Easy?
Old Dec 24, 2015 | 12:59 PM
kickintheglass's Avatar
kickintheglass
I have to do this in the spring as my car approaches 60k but it looks very similar to a engine oil change.
https://www.myg37.com/forums/d-i-y-i...ssion-oil.html
Old Dec 24, 2015 | 01:01 PM
xnick101's Avatar
xnick101
I've never done it on our car but it is pretty straight forward but you need two people, one person to push the pedal and one person underneath. My friend works at a dealership so I get him to do all my service for really cheap.
Here's a video on how to do it on a g35 6mt
And this off the 370z forum
REQUEST: DIY Clutch Fluid bleed/swap/replacement. - Nissan 370Z Forum
Old Dec 24, 2015 | 01:04 PM
xnick101's Avatar
xnick101
I did this in my garage. Really easy like an oil change. Hardest part was trying to face the bottle in a way so the fluid would come to the opening of the bottle without kinking the line going into the transmission. But if you use the hand pump like in the DIY you won't have that issue.
Old Dec 24, 2015 | 02:43 PM
JSolo's Avatar
JSolo
Just say no!!!!!
What's this hang up with the csc tube? It connects the line from the MC to the CSC. You could say it's part of the CSC. The aftermarket hd csc already comes with this attached. It's just one tube assembly, not multiple. I can't imagine how it could fail unless the oring where it attaches fails.
When replacing the slave with a stock unit, it must be separated from the tube. There's an oring that attaches to the tube at the csc end. It's possible to damage this in the removal process. Not to mention the oring is probably deformed at this point anyways.
Why they call for replacement of the entire tube and not just the o-ring?? Good question. Perhaps there's other wear that occurs to this tube?
My guess is it's just part of nissan's half assed design just like the csc itself.
Review the pics in this thread for more details:DIY: Replacing Your Clutch, Pressure Plate, Flywheel, and CSC (Zspeed HD CSC) - Nissan 370Z Forum
faiz23
Nov 7, 2023 01:51 AM
demo401
Feb 4, 2016 03:50 PM
Demodave
Dec 22, 2015 02:05 PM
User 122320
Dec 21, 2015 10:03 PM
