6mt Trans upgrade?
Old Dec 17, 2015 | 04:39 AM
cougarxcguy's Avatar
cougarxcguy
6mt Trans upgrade?
Just curious if anyone knows of any performance upgrades/builds for the manual transmissions. pretty much done with engine and suspension upgrades and I cant find any kind of manual trans builds, thanks for your time
Old Dec 17, 2015 | 07:23 AM
PongSanity's Avatar
PongSanity
6mt Trans upgrade are
Clutch changes
Csc replacement
Msc replacement
Old Dec 17, 2015 | 09:26 AM
What are you looking to "upgrade" on a manual transmission? Do you mean upgrades to the clutch or the shifter?
Old Dec 17, 2015 | 09:43 AM
chilibowl's Avatar
chilibowl
The transmission can withstand very high levels of horsepower. Its life is more dependent on the clutch disk you have, and making sure your master and slave cylinders are heavy duty.
Old Dec 17, 2015 | 10:33 AM
jwick's Avatar
jwick
Nobody has figured out how to break one yet and I know guys running 1000hp. If the clutch, CSC and MSC are good, you're good!
Old Dec 17, 2015 | 05:30 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Put in shorter rear end gears. That will completely transform the car.
Old Dec 18, 2015 | 04:48 AM
cougarxcguy
I have a Spec supertwin wilwood master and upgraded csc, i was asking about syncros, forks, and bearings. .. just want to make it Bullitt proof
Old Dec 18, 2015 | 08:44 AM
chilibowl's Avatar
chilibowl
There's no reason to bulletproof something thats already bulletproof. lol
The manual transmission in a 2003 Nissan 350Z = Garbage
The manual transmission in a 2009-2015 Nissan 370Z = Bulletproof
Youre good bro. Just move on to something else to modify.
Old Dec 18, 2015 | 11:24 AM
cougarxcguy
Thanks for the input guys
Old Dec 20, 2015 | 08:58 AM
While not a transmission upgrade per se, this here is certainly a worthy 6MT upgrade:
370Z & G37 AFP Clutch Pedal Assemblies - *RJM Performance.com
Also, some people replace the tension spring on the shifter, with very minimal effect, AFAIK:
https://www.z1motorsports.com/transm...ng-p-7355.html
And of course you could replace your shifter for something designed for a shorter throw:
Nissan 370Z Short Throw Shifter
If your clutch slave cylinder hasn't failed yet, you could get ahead of that problem with a proven aftermarket model:
https://www.z1motorsports.com/z1-pro...it-p-7340.html
And I suppose you could swap in a different formula gear oil. Redline MT-85 is very popular.
All that stuff is peripheral, because as stated, the tranny itself is pretty solid.
Old Dec 20, 2015 | 02:55 PM
clayzoo's Avatar
clayzoo
If you haven't already bought a clutch pedal spring from jsolo I'd highly recommend it, also bleed your clutch system and replace it with gtr brake fluid to get a better smoother feel from it. Other option is mtec shifter springs for the side to side movement of the gear lever for smoother gear changes. Just a few ideas
Old Dec 21, 2015 | 02:10 PM
jwick's Avatar
jwick
What modification did you have to do to get the Wilwood MSC to fit or did they come out with a G37 MSC recently and I missed it?
Old Dec 21, 2015 | 08:57 PM
cougarxcguy
When i ordered the spec super twin it had a hydraulics upgrade kit for another $399 i think it was. It came with the upgraded csc and wilwood msc. It had a aluminum plate to adapt it to our cars and all steel braided lines. Let me promis you, it is way larger than the oem!!!!The most difficult thing i have done!!!! Took longer to do the master than the clutch lol
Old Dec 22, 2015 | 11:16 AM
jwick's Avatar
jwick
You have a link to what you bought? I doubt I'd have the room to run (my boost MAP sensor and Greddy Gauge box are now in that compartment too) it if its as big as you say is but nice to have options.
Old Dec 22, 2015 | 04:11 PM
cougarxcguy
SPEC Clutches & Flywheels: Auto Parts, Domestic, Import, Truck, Racing, Drifting Results By Car its an option on there for the hydraulics upgrade. It doesn't give specifics about what it is, but the wilwood os what i recieved
