Anyone running a Catch Can Setup?
Old Jan 26, 2016 | 05:15 PM
dmallen2010's Avatar
dmallen2010
Just curious if anyone is running a Catch Can setup on their G? If so, what is your experience and results with your catch can setup.
For anyone that does know what a catch can is used for the below link does a decent job explaining,
Oil Catch Cans | Everything you need to know and more!
Old Jan 26, 2016 | 08:02 PM
Selym's Avatar
Selym
If you have enough blow-by to warrant a catch can, you may have other issues that need attention.
Old Jan 26, 2016 | 08:33 PM
dmallen2010
No excessive oil consumption here. It was just a question if some had installed one.
As a previous Chevy owner, the Corvette/G8/SS owners seem to use one to keep their intakes clean. Not saying it's a necessity.
So to keep your intake clean are you putting some Seafoam in your gas tank every so often? Or clean your throttle body with some throttle body cleaner every 20-30k miles.
Old Jan 26, 2016 | 09:17 PM
PongSanity's Avatar
PongSanity
Many are running catch cans. Anmvq is the last person I know to put on one. Many others are running the jdm half coolant reservoir and oil catch can. I'm getting one when I go force induction.
Old Jan 27, 2016 | 08:12 AM
ANMVQ's Avatar
ANMVQ
I am running a catch can set up. I like it, I've yet to have to empty it tho, not lots in there.
Old Jan 29, 2016 | 07:27 PM
Abramite's Avatar
Abramite
If you live in a old climate, there is a chance the liquid in there can freeze... Then you run into real problems.
Old Feb 2, 2016 | 04:43 PM
hooey_b's Avatar
hooey_b
Oil doesn't crystalize, so technically it can't freeze. Just becomes more viscous. If there's something in there other than oil blow by, THEN you've got problems.
and how would that be a "real" problem...? curious.
Old Feb 3, 2016 | 11:33 AM
PongSanity's Avatar
PongSanity
The real problem is when oil doesn't warm up to operational temperature. Hence oil coolers can come with thermostatic sandwich plates.
Old Feb 3, 2016 | 10:00 PM
Epiphany's Avatar
Epiphany
How is that a problem when it's sitting in the bottom of a catch can though? The plates with oil coolers are to help protect the inside of the engine.
Old Feb 3, 2016 | 10:15 PM
PongSanity's Avatar
PongSanity
I was talking about oil in the engine. What's in the catch can won't do anything.
Old Feb 4, 2016 | 10:54 AM
Abramite's Avatar
Abramite
I had one on my GTI and I never had a lot of oil in it, it was mostly a watery liquid, it froze completely. It can cause pressure build up in the crankcase if the line gets blocked.
Old Feb 4, 2016 | 12:46 PM
hooey_b's Avatar
hooey_b
So it sounds to me like y'all aren't keeping up with emptying your cans.
Old Feb 4, 2016 | 01:09 PM
Selym's Avatar
Selym
...or, the catch can is more a liability than an asset.
Old Feb 4, 2016 | 02:17 PM
hooey_b's Avatar
hooey_b
Have you cleaned your intake manifolds and throttle bodies yet? For its purpose, I don't think "liability" is a very apt description.
That's the reason why I bought one.
Old Feb 4, 2016 | 06:40 PM
Abramite's Avatar
Abramite
Cars do just fine without them... It's just another piece of equipment you have to monitor... In my opinion a daily driver doesn't need it.
