Check engine light
Old Feb 2, 2016 | 11:25 AM
infiniticrew860's Avatar
infiniticrew860
Check engine light
My check engine light just came on and I ran the diagnostic engine check and its said it was the map sensor range/performance. How much do these run for and is it safe to get it any other place than the dealer? How long do I have to replace it before somthing bad happens?
Old Feb 2, 2016 | 12:37 PM
micafd3s's Avatar
micafd3s
have you tried cleaning it first...
Old Feb 2, 2016 | 12:47 PM
infiniticrew860
No I haven't
Old Feb 2, 2016 | 01:01 PM
MaQG37's Avatar
MaQG37
Try this first.
DO NOT touch the filament. Spray it from both sides with CRC MAF cleaner. Let them air dry completely. Put them back in. Done.
Old Feb 2, 2016 | 02:55 PM
CPJ LB's Avatar
CPJ LB
If the code is pointing to the MAP sensor, check for any loose hoses and/or vacuum leaks... or change out the MAP (Manifold absolute Pressure) sensor.
The MAF (Mass Air Flow) sensor is something different.... that can be cleaned and it's located near the air filter housing.
Old Feb 2, 2016 | 03:46 PM
SonicVQ's Avatar
SonicVQ
Post the exact code. Sometimes the internet get the description wrong.
Old Feb 2, 2016 | 04:55 PM
infiniticrew860
This is what it read
Old Feb 2, 2016 | 06:18 PM
SonicVQ's Avatar
SonicVQ
Possible cause:
(1) Harness or connectors (The sensor circuit is open or shorted.)
(2) Manifold absolute pressure (MAP) sensor
(3) Intake air leaks
The code is the SYMPTOM not the cause. If you don't have the skills and tools to troubleshoot, take it to the dealer or a good independent.
To troubleshoot:
Use a OBD-2 scanner and look at the value of PID 0x0B. With the engine off is should be around 100 KPa (assuming close to sea level) and with the engine running at idle about 25 KPa.
Old Feb 2, 2016 | 06:50 PM
infiniticrew860
It's the map sensor. The dealers charging me 245 for it.
Old Feb 2, 2016 | 07:45 PM
salmonslayer's Avatar
salmonslayer
I'd buy that part off amazon or something and replace it yourself
Old Feb 2, 2016 | 09:28 PM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
Where are you located I have a spare that came with a manifold I bought I'll sell it to you for 40 shipped..
Old Feb 2, 2016 | 09:46 PM
infiniticrew860
I'm from CT. Does the part have to match with the vin #
Old Feb 3, 2016 | 01:18 AM
chuckie311's Avatar
chuckie311
Nope it does not its just a generic part!
Z1 sells them used and they are way closer to you only 69
https://www.z1motorsports.com/oxygen...hr-p-8985.html
Old Feb 3, 2016 | 07:30 AM
CPJ LB's Avatar
CPJ LB
shout out from CT!! maybe we'll cross paths one day.....
Old Feb 3, 2016 | 08:40 AM
infiniticrew860
Where you from?
