Help!! Mechanic Put 6 Quarts of oil in car!
Old Jan 10, 2016 | 07:26 PM
Snipres's Avatar
Snipres
Got a oil change yesterday, and my mechainic put in 6 quarts of oil even tho, i told him to crack the 6th and only put 1/8th in...
What do i do? When he checked the dip stick it was way above the the top hole..
Is their a way i can take some out throught the dipstick??
Do i just go back?
Don't really know what to say to him considering he is a family friend.(dont want to sound like a ****)
Is their anything that can happen in my commute tomorrow to work because of this overfill? 15 degrees tomorrow morning
THanks guys
Old Jan 10, 2016 | 07:30 PM
Do i just go back?
THanks guys
Drain into a clean pan and refill, that's what I'd do, I wouldn't drive it when overfilled that's for sure.
Old Jan 10, 2016 | 07:35 PM
bobtaz13's Avatar
bobtaz13
Loosen the oil filter, drain some oil. Recheck level. Keep doing it till the level is correct.
Old Jan 10, 2016 | 07:50 PM
No, that's a mess and a PITA.
Just do what Brad said... drain it completely and start over.
https://answers.yahoo.com/question/i...9084218AADdI3x
Old Jan 10, 2016 | 08:24 PM
Snipres's Avatar
Snipres
Just gona wait until after work tomorrow. I already beat the **** out of it yesturday after i reset the ecu...... Just gona baby it yomorrow
Old Jan 10, 2016 | 09:51 PM
qmantran's Avatar
qmantran
Ridiculous. You call this guy a mechanic and yet he can't even properly fill the correct amount of oil for a oil change?
1. You even told him how much to add
2. It's 2016 anyone can simply Google the correct oil fill capacity for any vehicle if unsure.
I don't know about you, but i wouldn't trust him doing a tire rotation.
Old Jan 10, 2016 | 09:56 PM
Upscale Speed's Avatar
Upscale Speed
Lossen drain plug most of the way and let some oil out until you get 3/4 a quart out. Then retighten and check oil level. That or do what Brad said.
Old Jan 10, 2016 | 10:29 PM
dkmura's Avatar
dkmura
20 Year Member
Having too much oil in the crankcase is almost as bad as having too little. You've already done some damage by "beat the **** out of it yesterday" and now you want to "baby it tomorrow" before you correct the problem? You must not care much about your G to treat it like that!
Old Jan 10, 2016 | 11:12 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Here's the problem with just loosening the drain plug. These cars use a strange compression type copper drain gasket. It compresses when you tighten it. Once compressed, it doesn't decompress when loosening. If not replaced, there's a chance you may get a leak.
I should ask, did he even replace the drain gasket??
So, as this is a family friend and his screw up, he should pay for a proper oil change by a qualified technician.
With respect to tire rotations, if this guy can't do a basic oil change, it's possible your wheels may fall off after his rotation! Or you'll end up with warped rotors because he overtorqued the lugnuts.
Old Jan 10, 2016 | 11:32 PM
antirice's Avatar
antirice
You don't have to replace the crush washer every time. I have never heard a g owner on the forum leaking oil due to reusing the washer.
I personally replace it every 3 oil changes. Never had a problem.
Old Jan 11, 2016 | 12:48 AM
35Sport's Avatar
35Sport
Wouldn't do this as you're likely to get any sediment from the pan straight into your engine.
Old Jan 11, 2016 | 06:52 AM
greco65's Avatar
greco65
Where I am they do oil changes during lunch time with conventional oil for $19.99. Bite the bullet and do another oil change than buying a new engine.
Old Jan 11, 2016 | 07:27 AM
micafd3s's Avatar
micafd3s
Originally Posted by antirice
You don't have to replace the crush washer every time..
this..
been flippin the washer then discard after second use for three decades now...
to the op... not sure why u beat the crap out of it after having the concern...
Old Jan 11, 2016 | 07:29 AM
Note that Brad said "into a clean pan".
Old Jan 11, 2016 | 03:11 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Normally I would agree with you. I'm comfortable reusing the washer for the diff or gearbox as it's just a standard 2.5mm or so aluminum washer. The one used for the oil pan drain plug is different from any other drain washer I've ever used. It's an accordion style copper piece that compresses to barely 1mm thick. Given this design, I'm not comfortable reusing it. It may actually take a bit more torque to seal it the second time around too. Washers are cheap to replace, stripped out oil pans are not.
To the guy above that mentions flipping it around, what purpose does that serve? Your probably deform it more removing it. Not sure how long nissan has been using this copper accordion design, but doubt it's 3 decades.
So, ymmv. If you're ok reusing it, go for it. Name:  Z3fzxYA.gif
