engine swap compatibility
Old Dec 12, 2015 | 12:19 AM
big nick's Avatar
big nick
You might remember I made a post about blowing my engine a little while ago. The cars been sitting on the side of my house since, being that I have a daily and a work vehicle I haven't had much interest in rushing to fix it. My car is 6mt rwd and I found an engine locally but the donor G is awd, and auto...does anyone know exactly what I would need to swap over to make it work other than the input shaft I would be swapping the entire long block. I've been looking and all I found so far is the oil pan is shaped differently so I would need to swap that.
Any other info would be greatly appreciated!!
Old Dec 12, 2015 | 09:00 AM
lownslow's Avatar
lownslow
Pan is different to make room for transfer case , you should be fine tho lay the engines side by side so you can "groom" the new ones you will have to swap the flywheel and any other components that are not the same as your original.
derekjl
Dec 9, 2015 11:05 PM
Broken_2008_G37
Dec 7, 2015 06:50 AM
H8Me909
Dec 6, 2015 12:17 AM
