To people who use the Torque Android OBDII app
Old Dec 17, 2015 | 09:40 PM
antirice's Avatar
antirice
Are you able to see the Cooling Fan readings? These are the sensor names:
[IADV] Cooling Fan High
[IADV] Cooling Fan Low
These two values always stay the same at "0", even though I can clearly hear the engine fans kicked in. I wonder if this is just a problem with the App itself.
Old Dec 17, 2015 | 09:54 PM
Mr_Mer's Avatar
Mr_Mer
Are you using the Advanced EX for Infiniti plug-in?
Old Dec 17, 2015 | 11:16 PM
antirice's Avatar
antirice
Yes sir.
Old Dec 17, 2015 | 11:21 PM
Mr_Mer's Avatar
Mr_Mer
I seen those PIDs, but don't use them. All I can tell you is that I'll try them in the morning and see if I can make them work
Old Dec 18, 2015 | 06:35 PM
Mr_Mer's Avatar
Mr_Mer
Well, I was playing mechanic today (R2C installed) and after running around at different engine loads and speeds went to work on this Torque thing... no dice. Even when the car was warm and the cooling fan going no signal showed up. So I don't know what else to do.
Old Dec 19, 2015 | 12:28 PM
antirice's Avatar
antirice
Looks like it might be an issue with the Torque app itself. Thanks for sharing.
bmbweber
Jan 4, 2016 12:11 PM
beng37s
Dec 22, 2015 05:28 PM
Shunny
Dec 19, 2015 06:16 PM
big nick
Dec 12, 2015 09:00 AM
