2012 Infiniti G37 Auto Transmission fluid
Hi there. I bought a 2012 Infiniti G37 Journey Sedan about 1 month and a half ago. I love the car.
As I was reading the service manual regarding replacing the automatic transmission fluid, it has a fine print to change the fluid under severe condition except 7speed transmission, which is what I have.
Does this mean that I should not replace the fluid in my transmission or is this otherwise? Thanks.
Some have done a full flush at 30k miles (a bit overkill IMO) others do a drain & fill (about 5-6 qts) every 30k, I did a full DIY 3x drain & fill at 70k and dropped the pan for a better cleanout, and some NEVER have the fluid serviced.
Here's the 3x drain & fill/pan drop DIY link, not overly complex but not as simple as most ATs.
https://www.myg37.com/forums/d-i-y-i...rop-clean.html
Koval88
12-09-2015 06:09 PM
