Help 2008 g37s compression test and spark plug question
Old Sep 29, 2018 | 06:36 PM
Jamie Nguyen's Avatar
Jamie Nguyen
so I have a 2008 g37s coupe
125000 miles
this car I bought used couple years back and has raised questions on what was done previously to the car
I got the car around 60k and now it’s way over due on spark plugs
is it possible for old spark plugs gaps move over time?
i got anywhere from .034 - .056 on the old ones and they were really really old lol wtf
supposed to be at .044 (.043 nismo 370z apparently)
so I did a compression test and got 225 - 230 psi with the motor cold and was wondering if that was too high!?!? Possible oil or coolant?
Note i had my throttle bodies out
btw searching for fuel pump relay sucks or I suck at searching so this might help some
it’s the first 15a fuse for fuse pump
and the fuse box is next to the battery
remove pass side windshield cowl
remove battery(just do it)
push two top tabs on the fuse box and lift entire fuse box up(just do it you’ll save time instead of fighting it)
then you can reach the bottom tabs to open the box
detach the entire fuse box by pulling the box up and holding tabs,
Thanks in advance
Old Sep 29, 2018 | 09:48 PM
slartibartfast's Avatar
slartibartfast
Your compression numbers are good.
Spark gaps change over time as the electrodes slowly erode in the hellfire that is combustion. Unless you measured them new, you have no idea what the original gaps were.
Old Sep 29, 2018 | 11:07 PM
Jamie Nguyen
thanks for the help!! But gaps that bad?!?
Old Sep 30, 2018 | 07:42 PM
slartibartfast
As I wrote, you have no idea what the original gaps were. They could have started that badly.
Jamie Nguyen
Jul 22, 2019 12:31 AM
Eddystone
Apr 12, 2015 11:48 PM
Abdul Sabtan
Feb 2, 2015 06:45 PM
koelzmod
Oct 3, 2008 01:01 AM
