Help is it possible that a faulty pump can cause error p0300
hey, is it possible that a faulty pump can cause error p0300 and throttle the car at the same intervals? (10s)
in emergency mode has less power but does not choke (another map with a smaller dose of fuel ??)
sometimes p0300 is with 0011 and 0021
g37x from 2013r
g37x from 2013r
Not quite sure what you're trying to say. Do you mean the oil pump failing? Baffled by your throttle portion. As for limp mode, rpm is limited but the engine is allowed to run so you can reach home or the dealer/shop.
jose_aoc
14
Jul 27, 2018 03:20 PM
avsBuddy
TSB - Technical Bulletins
Dec 30, 2011 12:49 PM
MaxToTheG37
Nov 25, 2010 08:54 AM
