code P0300
Old Apr 15, 2015 | 09:20 PM
ggggg37's Avatar
ggggg37
code P0300
Hi, I just read the code P0300 from my g37s coupe 2008 6MT. They say that a cylinder(s) is misfiring or is randomly misfiring. Start by checking for intake leaks, intake gaskets are common caused of multi-cylinder misfiring. If no leak are found the next step is to replace the spark plugs.
My car was shaking at idle, and the rpm was high around 1000. I lost power and whenever I was accelerating from stop, it felt as if I was starting from fourth or fifth gear. Did someone experience something similar?
thanks,
Old Apr 16, 2015 | 12:09 AM
vqsmile's Avatar
vqsmile
How many miles are on your car?
Has it had regular maintenance done on it?
Old Apr 16, 2015 | 07:28 AM
ggggg37's Avatar
ggggg37
It has 80K miles. I change the oïl regularly for synthetic, use 94 gas, installed the Takeda long cold air intakes last summer. at 65K miles made a maintenance at the dealer, they said everything was fine. Besides that nothing.
Old Apr 16, 2015 | 10:12 AM
properdropper's Avatar
properdropper
bro! my car seriously was doing the same same error code and everything, mine had a misfire as well. i got it fixed by my friend who works at nissan, all i did was buy 6 brand new OEM spark plugs, and new ignition coils, problem gone, my G37 journey has about 71K miles on it so it was about that time anyways.
Old Apr 16, 2015 | 01:35 PM
ggggg37's Avatar
ggggg37
Thanks!
Should I tow the car to the garage or is it okay to drive?
Old Apr 21, 2015 | 05:34 PM
ggggg37's Avatar
ggggg37
went to a mechanic, he says that he has to put back on the original intakes, then if the problem persists, he will check the mass air flow sensors.....
I installed the Takeda intakes last summer, never had a problem since recently, I doubt that is the problem...
What do you guys think?
Old Apr 21, 2015 | 07:41 PM
properdropper
Originally Posted by ggggg37
Thanks!
aww bro im sorry i just now saw the reply... total bummer, it was safe for me to drive it for the few days i had to, just didnt floor it and do the unnecesarry revs from a take off lol but im still so sure its the spark plugs and coils. maybe your throttle bodies could be dirty too? my friend from nissan said mine were and he also cleaned those when he fixed my misfire.. cause when i would start the car it would idle really rough and my car would shake really bad. but after the new ignition coils and Spark plugs it all went away its been fine since...
Old Apr 23, 2015 | 11:50 AM
ggggg37's Avatar
ggggg37
Now I get P0021 code as well, think this one causes the P0300. Did you get this one as well?
Old Apr 23, 2015 | 03:57 PM
canucklehead's Avatar
canucklehead
^ lots of discussion on those codes on the forum. do a search and you'll see. you can also google the codes to find out what the definition of each is. i assume you are out of warranty. hopefully you are not dealing with the rear timing cover leak messing with the valve timing solenoid. are you in limp mode (can't rev past ~2500rpm)?
Old Apr 24, 2015 | 07:04 AM
ggggg37's Avatar
ggggg37
Yes I am un limp mode
Old Feb 24, 2021 | 03:14 PM
TEAMMI's Avatar
TEAMMI
Did you ever figure out what the issue was? I am having same issue and just put on the Takeda intakes not too long ago. The mechanic told me same thing.
Old Jul 12, 2021 | 06:22 PM
mikezila71's Avatar
mikezila71
anything ? I have same problem
JT808
18
Nov 9, 2025 01:52 PM
bgoodman
16
Oct 26, 2019 11:46 AM
jrbeavers559
Jun 28, 2018 09:41 PM
Huaniitoo
Jun 24, 2018 06:20 PM
MatthewakaMatt
General Tech Questions
Jan 6, 2016 09:09 AM
